.htaccess file is not copied over when I use BitBucket Pipelines
venkatcss October 15, 2019 edited
Hi Team,
.htaccess files is not able to copied into server using bit-bucket pipeline , can i know the reason why like hidden files are not able to update the changes into server, when ever we have modified the bitbucket repository.
bitbucket-pipeline.yml
image: ubuntu:16.04
pipelines:
branches:
DevStaging:
- step:
script:
- apt-get update -y
- apt-get install -y zip
- apt-get install php libapache2-mod-php -y
- apt-get install curl -y
- zip -r artifact.zip *
- apt-get install sshpass -y
- time sshpass -p 'password' scp -o StrictHostKeyChecking=no -o LogLevel=DEBUG artifact.zip username@ipaddress:/home/usrname/deploy
Can you please give the solution ASAP.
Venkat
mkleint
October 20, 2019
I assume that `zip -r artifact.zip *` is the step that should include the .htaccess file in your repository?
I believe zip by default will not include files starting with .
https://unix.stackexchange.com/questions/423017/how-to-zip-all-files-including-hidden-files-to-zip-file-using-linux-command
venkatcss October 20, 2019
Yes I want to zip including .htaccess file also can you please guide me. what are the changes i want to do here ?
image: ubuntu:16.04
pipelines:
branches:
DevStaging:
- step:
script:
- apt-get update -y
mkleint
October 20, 2019
see the linked stackoverflow answer.
zip -r artifact.zip ??*
venkatcss October 21, 2019
Hi Mkleint,
Thanks for your's reply , I have tested using the command " zip -r artifact.zip ??*" but no luck. Hidden files are not zipping.
bitbucket-pipelines.yml
image: ubuntu:16.04
pipelines:
branches:
Ydtwebstaging:
- step:
script:
- apt-get update -y
- cd admin/back-end
- zip artifact.zip ??*
- time sshpass -p 'password' scp -o StrictHostKeyChecking=no -o LogLevel=DEBUG artifact.zip username@ip:/home/username/deploy
- step:
image: node:10.15.0
script:
- apt-get update -y
- cd admin/front-end
- npm install
- CI=false
- npm run build
- zip artifact1.zip ??*
- time sshpass -p 'password' scp -o StrictHostKeyChecking=no -o LogLevel=DEBUG artifact1.zip username@ip:/home/username/deploy
- step:
script:
- apt-get update -y
- cd Mobile_API_Setup
- zip artifactapi.zip ??*
- time sshpass -p 'password' scp -o StrictHostKeyChecking=no -o LogLevel=DEBUG artifactapi.zip username@ip:/home/username/deploy
Like this i have used in my config file but it's not zipping the hidden files
Venkat
mkleint
October 21, 2019
Ok. This question is not specific to pipelines. It's a general linux usage question. I've found this solution to work in my ubuntu docker image
root@b82cdad66040:~# zip 1.zip * .[^.]*
adding: file (stored 0%)
adding: .bash_history (stored 0%)
adding: .bashrc (deflated 54%)
adding: .dotted (stored 0%)
adding: .htaccess (stored 0%)
adding: .profile (deflated 20%)
as per this stackoverflow - https://stackoverflow.com/questions/12493206/zip-including-hidden-files
Not sure if it only works in root folder or includes dotted files recursively.
atlassian, forge, forge learning path, atlassian learning, cloud app development, forge app development, build forge apps, atlassian certification, developer training, jira app development, confluence app development, automation, ui frameworks
Turn Ideas into Atlassian Apps 📱
From setup to deployment—this learning path shows you how to build your first app using Forge. Learn the essentials, streamline workflows, and bring custom solutions to life across Jira, Confluence, and more.
Start Learning
