I have done all the commands asked of in the terminal, everything works is good to go until I have to enter my password. I have checked the password a hundred times lol.
it keeps saying invalid credentials. this is for Ruby Rails(class on web applications) by the. I have some homework I'm trying to turn in, also a first-time user. I even went and made a token thinking that would work that didn't either. just frustrated
Hey @Bonny Makaniankhondo ,
and welcome to the community!
Based on your description, it seems like you're facing authentication issues.
In order to authenticate git operations over HTTPS, you need to provide your username (which you can find under your Personal Bitbucket settings), along with an App Password (it's not the same password you use to login in the UI).
In this case, if you haven't already, could you please create an app password and provide it as the credential when trying to interact with your repository ?
Let us know in case you have any questions.
Thank you, @Bonny Makaniankhondo !
Patrik S
