On local it takes 1.5 mins and on bitbucket it takes 3 mins.
If your memory settings in your YAML config are less than your available memory in your local environment - this would affect the build time. You might want to take a look at the size option in your step configuration if this is the case:
If you're still encountering issues - please raise a support ticket so we can troubleshoot this further with you:
Cheers!
- Ben (Bitbucket Cloud Support)
@Ben I am currently using 4x.
Another thing is that for some pipelines, when i run the tests again and again the time is same for the some pipelines. But for some pipelines it is sometimes 1 min 25s and some times 1 min 40s (huge time gap), it shouldn't be happening. (i am talking here about execution time of the tests, not the bitbucket pipeline whole time)
Same Pipeline:
1st time
2nd time
I have raised a support ticket on your behalf with our support team. In future, for any troubleshooting on pipelines issues - we require a support ticket to be raised so that we can grant ourselves access to your workspace and check your build environment/logs (our system requires this):
Please check your email for further correspondence.
Cheers!
