image in bitbucket-pipelines.yml for Boost includes and libs
Sergey Kurchatov December 16, 2021
I cannot add Boost includes and libs into my pipeline
My CMakeLists.txt contains line
find_package(boost_REQUIRED)
It works in my local server but it does not work in the pipeline:
Unable to find the Boost header files. Please set BOOST_ROOT to the root
directory containing Boost or BOOST_INCLUDEDIR to the directory containing
Boost's headers.
My simplified  bitbucket-pipelines.yml is below:
image: zouzias/boost
pipelines:
default:
- step:
script:
# Install Boost
- docker pull zouzias/boost:latest
# Call the CMake.
- cmake ..
services:
- docker
What is wrong?
Could you share a sample  bitbucket-pipelines.yml and CMakeLists.txt that uses Boost includes and libs?
Thanks in advance
Sergey
Jason McGuiness
August 29, 2022
I tried adding this to my ".yml" file:
 - step:
script:
- apt update && apt -y install cmake libboost-dev && apt -y upgrade
