×Hi,
I want to import a SVN repository dump but is it possible to import it only into the space for once projet.
For example I have a projet FARPRECL with its svn URL "https://farpbq.atlassian.net/svn/FARPRECL" and I would like the import to go only into this subfolder, it is possible to do so with your "Import SVN Repository" option ?
Thanks in advance,
Pascal Chouinard
It is possible to do, but you need to rearrange your repository structure so that the top-level of the repository contains directories for all project keys. Methods to do this are described here.
svn-dump-reloc reliably creates corrupt dumps. Perhaps it's time to update the document with something that actually works.
svn-dump-reloc reliably creates corrupt dumps. Perhaps you need to update that document with something that actually works.
