is it possible to create multiple projects but use single SVN repo?
nikita tovstoles April 3, 2012
We currently have a JIRA project with KEY "CLP". The project has an associated subversion repo (under /svn/CLP/ in Fisheye). We'd like to create an additional project (say "FOO") but point them at the existing "CLP" subversion repo (such that issues' "Source" tabs would display commits to CLP svn repo if commit log message contained FOO issue key ie. "FOO-100". Is that possible?
Thank you,
stein-gran
May 31, 2012
I had the same problem as dukehoops here, and I am disappointed to see that such a setup is not possible with Jira OnDemand. we have a pretty big product with several parts (UI, CORE, SQL), and we have found it best to have separate projects in JIra for these. But now we'll have to reconsider that setup.
Could you please add this as a feature request for your next product release?
James Maes
August 22, 2012
Same here - we are trying VERY hard to move to ondemand for a 20MM line application that is across several projects - but currently a single repo.
With legacy projects - you rarely have a one to one mapping between projects and repo's.
We REALLY need some way for this to work. Can support setup the links for us once we have the projects and repo's created?
Sébastien Richer August 21, 2012
This is very much an essential feature, anyone with projects bigger than small will absolutely need this. How can we push this up to a feature request? This could be a show stopper for us.
132412341234
valentino miazzo
July 25, 2012
Same problem here.
The rationale behind how we organize code in SVN and how we organize tickets in JIRA are different.
On SVN we do fine grained splits in order to increase code reuse.
On JIRA the point of view is the one of the project manager and the fine SVN structure provides too much detail.
This 1 to 1 mapping doesn't make sense.
rverschoor
April 25, 2012
In standalone FishEye and JIRA this is easy to accomplish.
Just add an extra Application Link to the CLP repository in FishEye, pointing to the FOO project in JIRA.
You end up with two Application links from the CLP repo, one to CLP and one to FOO.
However, in an OnDemand instance you don't have this level of control.
When a JIRA project is created, it creates the SVN and FishEye configuration for you.
There's a fixed 1-on-1 relation between teh products, you can't add extra Application Links.
So what you want to accomplish is not possible in OnDemand.
Dennis Kromhout van der Meer
April 10, 2012
I talked to FishEye support and we're going to try this tomorrow. In the meantime, can you provide your version numbers for JIRA and FishEye? Thanks!
Learn more
