I'm trying to delete repo by UI and by API request but without success.
in UI stuck with loading (without any details).
and by API I got:
requests.exceptions.HTTPError: Repository currently not available.
please need help - this issue affect my work
G'day!
Thank you for contacting Bitbucket Cloud Support.
This issue was caused by the following bug - I have proceeded to delete it manually from my end:
Cheers!
- Ben (Bitbucket Cloud Support)
Thank you very much
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
