pipe: atlassian/jenkins-job-trigger:0.1.2
Shahar Senior
June 1, 2022
When Trigger job with parameters
JENKINS_URL: $JENKINS_URL
JENKINS_USER: $JENKINS_USER
JENKINS_TOKEN: $JENKINS_TOKEN
JOB_NAME: 'myJob'
JOB_PARAMETERS: { 'Commit_Hash': '$BITBUCKET_COMMIT' }
WAIT: 'true'
DEBUG: 'true' # Optional
 The Pipe Failed with :
✖ Pipe has failed with error:
HTTP ERROR 400 This page expects a form submission
You need to post /job/myJob/buildWithParameters instead of /job/myJob/build
lissyaka June 3, 2022
@Shahar Senior  hi. This is a bug in the pipe. We will investigate this issue and update the pipe.
But there is a hidden feature you can use instead:
JOB_NAME: 'myJob'
BUILD_FROM_FILE: 'path to the file with parameters'
WAIT: 'true'
 where you can paste all your job parameters.
Cheers.
Manish Pal
June 14, 2022
@lissyaka
I created a file build.json with params in the root dir of the repository.
I am trying to set BUILD_FROM_FILE parameter with $
BITBUCKET_CLONE_DIR/build.json
It says Jenkins jobfile doesnt exist on running the pipeline.
Have tried with just setting value as build.json as well. Same error.
lissyaka June 15, 2022
I will check this
lissyaka June 16, 2022
@Manish Pal. This pipe checks if file present in directory.
Also there is a test that checks if build from file is working correctly.
Please, ensure you have a file when you run the pipeline.
To do this you can:
step:
script:
- ls # check your file is presented
- pipe: atlassian/jenkins-job-trigger:0.1.2
variables:
JOB_NAME: 'myJob'
WAIT: 'true'
Igor Stoyanov
June 30, 2022
@Shahar Senior @Manish Pal  we released a new version of jenkins-job-trigger:0.2.0 where we fixed usage of BUILD_FROM_FILE and JOB_PARAMETERS.
script:
  - pipe: atlassian/jenkins-job-trigger:0.2.0
    variables:
      JENKINS_URL: 'http://my-jenkinsio-host/job'
      JOB_NAME: 'staging-awesome-project-job'
      BUILD_FROM_FILE: 'path_to_file_from_repo/jenkins_file'
      JENKINS_FILE_PATH: 'path_to_file_on_jenkins_job_parameter/jenkins_file'
      WAIT: 'true'
      WAIT_MAX_TIME: 120
script:
    variables:
      JOB_PARAMETERS: >
           "test1": $TEST1,
           "test2": "test2"
      WAIT: 'true'
      WAIT_MAX_TIME: 120
Please, provide us feedback if all works as expected.
Regards, Igor.
Patrik S
June 2, 2022
Hello @Shahar Senior ,
Welcome to Atlassian community!
From the error message you received it seems that when using parameters Jenkins expects you to call the /buildWithParameters endpoint, instead of /build
Could you please try updating your $JENKINS_URL to call the /buildWithParameters endpoint and check how it goes?
Let me know in case you run into any issues or have any questions.
Thank you, @Shahar Senior .
Patrik S
