pipeline build ran but not shown in the pr
Hod Bauer
December 23, 2024
I have a pipeline that do the following steps:
1. lint
2. test
3. collect coverage
If there is downgrade in one of  the coverage rate it should block the PR.
otherwise it update the threshold and commit it to the already opened PR.
Sometimes although the pipeline is running and finish successfully to push back a commit with the new threshold it not show it anymore in the PR builds.
The pipeline is defined with the following steps:
 - step:
name: Lint and Test
caches:
- node
script:
- npm ci
- npm run lint
- npm run test-coverage
- npm run update-coverage
after-script:
- git config --global user.email "ci-bot@duve.com"
- git config --global user.name "CI Bot"
- git add jest.config.json
- git commit -m "[skip ci] Updating test thresholds based on tests results"
- git push origin HEAD:$BITBUCKET_BRANCH
The project is written in js
The script `
update-coverage` run a js code that finish with `process.exit(0);` is there is no errors on run time and `process.exit(1);` if there is any error
Theodora Boudale
December 24, 2024
Hi Hod and welcome to the community!
When you open a pull request in a Bitbucket Cloud repo, the builds section in the Overview tab will show the build associated with the last commit in the PR's source branch.
Your pipelines build adds another commit to the source branch and then pushes it back to the Bitbucket repo, so then this commit becomes the last commit of the PR's source branch. If there is no build associated with this commit, then the PR will not show any builds.
What you can do is use our API to post a build status for this commit that you are creating during the Pipelines build:
You could do that either during the Pipelines build or from your own computer.
You will need the commit hash of the commit that is created during the build. You can get that during the Pipelines build and store it in a variable as follows (after you create the commit):
COMMIT=$(git rev-parse HEAD)
Depending on the exit code of the step that creates this commit, you can update the commit's build status accordingly.
If you want to update it during the build, in the after-script of the step, the default variable $BITBUCKET_EXIT_CODE is available which will be 0 for a successful step and 1 for a failed step. Valid values for the build state in the API call are FAILED, INPROGRESS, STOPPED, SUCCESSFUL. You can use the SUCCESSFUL state when the $BITBUCKET_EXIT_CODE is 0 and the FAILED state otherwise.
Please feel free to reach out if you have any questions.
Theodora
