pipeline: how to create a dependency between steps
Admin Admin January 23, 2022
 is there a way to make the "deploy" step wait for the "build" step?
issue:
 the download of the docker image for scp pipe takes 40 seconds and the actual copy of the artifacts - 2.
It would be good to have all the downloading done while "build" is in progress.
bitbucket_pipelines.yml
image: atlassian/default-image:3
pipelines:
default:
- step:
name: Build and Test
caches:
- node
script:
- rm -rf node_modules/
- rm package-lock.json
- npm install
- npm run build
artifacts:
- node_modules/**
- .nuxt/**
- package.json
- step:
name: Deploy npm_modules artifacts using SCP
deployment: test
script:
- pipe: atlassian/scp-deploy:1.2.1
variables:
USER : $DEP_USER
SERVER : $DEP_SERVER
REMOTE_PATH : '/tmp/test/'
LOCAL_PATH : 'node_modules/'
DEBUG: 'true'
Theodora Boudale
January 25, 2022
Hi @Admin Admin,
It is not possible to configure what you are asking, non-parallel steps are always executed sequentially and the previous step needs to complete for the next one to start. Parallel steps would not be a solution for your use case, as it is not possible for parallel steps to use artifacts by steps in the same parallel set.
What you could do to speed up the process would be to use a docker cache, this way the pipe's Docker image will be cached and then used in subsequent builds. You can modify the second step as follows:
- step:
deployment: test
caches:
- docker
script:
variables:
USER : $DEP_USER
DEBUG: 'true'
The cache will be saved after the first successful build and subsequent builds will use the cache for the pipe's Docker image. Any cache which is older than 1 week will be cleared automatically and repopulated during the next build:
https://support.atlassian.com/bitbucket-cloud/docs/cache-dependencies/
If cloning the repo during a pipelines build takes a long time, you could try adjusting the depth of the clone; the default is 50, but if you don't need that you could specify a lower value as follows in the yaml file
clone:
depth: 5 # include the last five commits
Theodora
Admin Admin January 25, 2022
@Theodora Boudale
 not what i was _hoping_ to hear. But thank you for clarifying the question for me.
Theodora Boudale
January 26, 2022
You are very welcome, please feel free to reach out if you ever need anything else.
Theodora
Pramodh M
Hi @Admin Admin
It's already dependent, If your step fails, succeeding steps will not be executed!!
There's a configuration to run steps in parallel
https://bitbucket.org/blog/speed-build-parallel-steps-pipelines
Pramodh
i do NOT want the dependent step to fail.
I'd like the dependent step to wait until the artifacts are created...
Pramodh M
Hi @Admin Admin
Since the Image where you are building the npm project, and SCP is happening in another pipe. This should go one after the other.
Pramodh
Admin Admin January 24, 2022
@Pramodh M,
 I maybe not be clear, apologies.
I'd like to kick off the deployment step before the artifacts in the build step are ready.
What I'm trying to do is :
1. step build and step deployment: downloads repos and dockers simultaneously
2. build is building;
3. deployment is waiting for the build to finish before starting the deployment.
Pramodh M
Yes @Admin Admin
I understood, Since we are using Pipe to transfer the file in the step, the docker image will be pulled at the moment in time.
If you are using a self-hosted runner there is a workaround, but with Atlassian, runners it's not efficient (You could try having npm build && docker pull image-name to keep the image before you run the next step where it uses docker image)
Pramodh
Like • Admin Admin likes this
