proper logical order when deploying multiple resources using cloudformation
dataking November 10, 2021
Hey community,
I am using bitbucket-pipelines.yml to deploy a cloudformation using the atlassian/aws-cloudformation-deploy:0.12.0 pipe and my lambda function to s3 using the atlassian/aws-s3-deploy:1.1.0 pipe.
I have all of my resources being created in the cloudformation template. The resources include an S3 bucket, and lambda function which is referencing the zip file code in the S3 bucket.
I keep running into issues because I cant ( or at least I dont think I can) put the S3 pipe before the cloudformation template because the bucket would not be created, and if I put the S3 pipe after the cloudformation pipe it will fail because the lambda function cloudformation step tries to reference the zipped code in the S3 bucket, which the S3 pipe is supposed to upload.
Any recommendations? I could potentially have separate cloudformation templates for each resource and create a new step in the bitbucket-pipelines.yml, but it seems a bit more challenging to manage all the files, but maybe not?
Any suggestions?
Igor Stoyanov
November 19, 2021
@dataking  hi. Thanks for your question. Try this to split logic:
step:
script:
  - pipe: atlassin/cloudformation-deploy:0.12.0
    <create s3 bucket from template>
  - pipe: atlassian/aws-s3-deploy:1.1.0
    <deploy to s3>
  <create lambda>
Regards, Igor
dataking December 6, 2021
Hey @Igor Stoyanov with this approach, wouldn't I require 2 separate cloud formation templates? In other words, step 1 would contain the CF for S3, where as step 3 would contain a separate CF template with lambda resources.
Is that correct?
Igor Stoyanov
December 7, 2021
@dataking hi. Yes, you need to create 2 separate cloudformation templates.
dataking December 7, 2021
@Igor Stoyanov how do you recommend to manage that at scale? Imagine we are dealing with many resources in the same repository.
Igor Stoyanov
December 8, 2021
@dataking  hi. Please, describe your case with more details.
Do you have known count of lambdas? And how many lambdas if count is known?
Regards, Igor.
atlassian, compass, developer experience, devex, platform engineering, internal developer platform, component catalog, atlassian learning, productivity tools, developer productivity, software architecture, compass webinar, engineering teams
Discover how Compass drives DevEx and productivity at Atlassian 🏃🏻‍♂️
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨
