"This is not a valid source path / URL" when connecting directly from Bitbucket
Andrew McDonald
A colleague set up a repository on Bitbucket and invited me to join. I've never used Bitbucket before, but registered and was able to view the project pages and source.
I followed the link to download SourceTree (on Windows 7 Ultimate x64 SP1), went through the setup wizard, and installed the internal Git and Mercurial packages. Now I'm clicking the SourceTree link directly in the Bitbucket page, but SourceTree states ""This is not a valid source path / URL" in the clone repository dialogue. There is a "Details" button next to the message, which simply produces an empty dialogue box.
This also happens if I browse in the "Hosted Repositories" dialogue. How can the path be invalid, if it's directly produced by the Bitbucket website or the SourceTree browsing process? What do I do next?
140 votes
Andrew McDonald
Thanks for the reply. Although not strictly a version issue, the first link provided some help. When SourceTree started for the first time, I skipped setting up Git & Mercurial in the wizard. Then I reran the wizard and chose to download and install the embedded packages. But it seems installing those didn't actually enable them - in the Tools -> Options dialogue they were both disabled! Enabling Mercurial allowed the clone dialogue to correctly identify the repo.
Shouldn't they have been enabled after installing the embedded packages through the wizard?
Gordon Kam
I couldn't agree more. Specially when there is no instruction to tell you to enable it. This should be done automatically or at least the help icon should tell you to check this.
Like # people like this
marcin April 7, 2016
Thanks, in my case i had external git so I switch to 'use system git' - version of git shows up, dialog "this is not valid source path" disapear and finally i can clone repo.
Nico Hunink June 5, 2018
Thank you for your reply!!
I updated both embedded stuff (Mercurial and Git) and it finally worked!! :-)
Thanks again and have a great day y'all ;-) B-)
Like vustsinovich likes this
augustbelhumeur
August 26, 2018
Does anyone have an answer for this for Mac users that don't have a "Tools" option in the menu bar?
BMYOUNG
September 19, 2018
I have SourceTree 2.6.10. I got the same error message. Based on the information in this thread, I went into Options/Git/Git Version and downloaded an embedded version. This fixed the problem for me.
Angela Wallace
May 13, 2019
@augustbelhumeur I'm sure you've found this by now, but for anyone else with a Mac, go to
  • Sourcetree > Preferences > Git > Git Version
  • Click "Use System Git" (via @marcin-sumologic 's response above)
At this point I was prompted to enter my system password twice to update my keychain password, and then this fixed the issue for me and I was able to pull code.
chandrasreddy
August 21, 2019
This worked for me
Like catalin3004 likes this
Avanika Gupta
August 29, 2019
Thank you for this answer. This helped and following resolved the issue:
Tools -> Options -> Git -> Git Version -> Click on "Embedded".
Breno Medeiros de Oliveira
January 9, 2020
Thank You Avanika Gupta!!
Only the "Embedded" button solved my problem on Windows!
Pratheek R
January 15, 2020
I'm on Windows, changing it to 'Embedded' did it for me.
Ahmed_ELharidi
May 16, 2020
It works for me after updating Git version.
Thanks.
15 votes
Federico Caramelli January 17, 2014
I have solved this one on Win 7 by going to
Tools -> Options -> Mercurial -> Update Embedded Mercurial
Toms Knostenbergs
November 12, 2019
This helped! Thank you!
8 votes
B Jagdish March 31, 2016
We had also same issue "This is not a valid source path / URL "and it got resolved by updating the Embedded Git of Source Tree.
Steps to resolve:
Open source tree, Tools -> Options -> Click on Git Tab -> Update Embedded Git.
Deleted user September 21, 2017
Hai Jagdish ,
i was a newbieee at using the source tree and bitbucket , followed ur solution it worked perfectly fine .
thanks for the info .
Like Uday Thej Sangineedy likes this
Huy Pham
December 1, 2017
thanks you
Alan Telford
June 25, 2018
Updating Embedded Git worked for me after restarting Source Tree, thanks
camilla_camatta
October 26, 2018
Thank you so much, it worked like a charm!
michael brodigan
April 11, 2019
This worked for me in Win 10. I had old version of SourceTree 1.9.13 I uninstalled this version and downloaded 3.1.2. Once I did the Update Embedded Git it worked.
Shawn Kim
September 5, 2019
Thank you! This worked perfectly, only wish I had found your answer sooner! (URL has been removed)
hongyan
September 27, 2019
It works perfectly. Thank you!
Sushree Sangita Sutar
November 4, 2019
After restart it worked fine for me. Thank you
Tran Huy
March 11, 2020
You totally saved my life. Many thanks !!!
Like Kyros_Tsourdinis likes this
Kyros_Tsourdinis
May 19, 2020
Thank you thank you thank you
5 votes
The-any-Key
August 15, 2017
I had the same issue "This is not a valid source path / URL "and it got resolved by updating the Embedded Git of Source Tree. I also got an error when trying to push (third party error ... setup password and username... to many failed password attempts...) and this solved that too.
Steps
sanjaybeedi
December 15, 2017
Worked for me.
pradeep.nanjundappa November 9, 2020
I am not able to resolve this error even after clicking on update embedded.
when i click on update embedded it downloads files, exract and after that i get option to select wincred, after selecting it the problem of invalid source path comes up. in the details it shows authentication failed. I tried to login with CAPTCHA into bitbucket but it is not resolved. Please help me to solve this ASAP.
Like Deleted user likes this
Varun.Joshi
March 9, 2021
For those, who might be using Sourcetree, please go to tools --> options --> authentication, click on the initials of your name, click manage and refresh the OAuth token once.
Then try cloning the repository again.
I am just a newbie but I was able to clone a bitbucket repository like this.
Thanks.
3 votes
Bamanyi
September 5, 2018
For Mac users
Go to application preferences and select the Git tab. Then click reset on all three buttons for Embedded Git, Git-Flow and Git LFS and that should do the trick.
brunosdecampos
February 8, 2021
Thanks! This worked for me! ;)
Neeta S
November 21, 2018
Tools -> option -> Network -> Check "Add proxy server configuration to Git/Mercurial". Hope this helps someone.
tunx406
March 14, 2019
thanks you. i clone successfully
Mousa Issa Alfhaily
August 30, 2019
Yeah... this worked for me! Thanks
Eddie Kumar
January 15, 2018
For me it was version conflict between the GIT Client & GIT-System-Installation , I ended up using the Embedded GIT (instead of System GIT), which resolved the issue.
To do so go to: Tools -> Options -> Git (tab) -> "Use Embedded Git" button.
HTH
aubs
May 27, 2018
Works for me. Thanks.
Syed Asad Ali
September 19, 2018
This works for me on MAC also. Thanks.
Vu Tran LVD
November 26, 2018
For me it was the other option, using
 Tools -> Options -> Git (tab) -> "System" button.
Like elumeyer likes this
Judyll
June 5, 2019
Tools -> Options -> Git (tab) -> Embedded
and then Tools -> Options -> Git (tab) -> Update Embedded
worked for me.  Thanks a lot!
I am not able to solve this error.I still get invalid source path. can anyone help me??
romeothethird
May 28, 2017
After setting everything to Embedded Git. I was still getting the same error, to solve this, I just ran the software as admin.
sudhan
July 16, 2017
i am also having same error pls help
Jonathan Lloyd
December 7, 2018
I had this same issue on a Mercurial repository after a password change in Bitbucket, I tried the solutions above, but I was still having issues.
The solution for me was to first update SourceTree and then update Embedded Mercurial.
  1. Tools > Options > Updates > Check For Updates and Update
  2. Update and Restart
  3. Tools > Options > Mercurial - Under Mercurial Version click Update Embedded, note the update to the Embedded Mercurial version number.
Deleted user December 14, 2020
Thanks for the suggestion it helped. Also, I had to Update Embedded for Git as well.
KieranA
December 11, 2013
Hey Andrew,
I've filed an issue on JAC here for you: https://jira.atlassian.com/browse/SRCTREEWIN-1316
The problem seems to be that neither the VCS required not being installed / utilised by SourceTree leads to a completely empty error message. We could be more helpful and say that a Git/Hg install couldn't be found with further help on how to set them up (i.e. "Would you like to set Git/Hg up now?") and take them through that process again.
Cheers
Andrew McDonald
Thanks Kieran. Filling in the error box would definitely help - users just need to be prompted to enable the embedded plugins if they've installed but not enabled them.
Benhafoune Mohammed-Tarik
July 20, 2017
you probably made a mistake in the password verify your account
Sean Jorgensen-Day
April 25, 2025
Why after at least 12 years are we still seeing this problem?
First computer I installed source tree on worked first time.
2nd computer and it had me going round in circles for days.
Nitin Gandge
April 8, 2022
Update Git and Mercurial versions by clicking on Embedded in Git & Mercurial Tab.(If Embedded option is enable it means it is not updated)SourceTreeIssue.png
Gonzalo Marecos
February 8, 2021
first check if you have git installed on your computer :#
Thomas Villadsen
July 12, 2019
In my experience a common mistake using your bitbucket email instead of the username.
This will cause sourcetree to report an invalid url, at least for basic authentication.
One should use the username registered in the bitbucket (can be found under profile)
I think that the reason for such confusion is that the bitbucket.org website, allows to use email as username, whereas the sourcetree application expects the actual username.
RonaK Bhagchandani June 26, 2019
I have face the same problem. Just check in tools->options->git tab-> select system git instead of embedded git. Then try to check http url.
Bernard Oreva
November 7, 2018
Did Git Version - > Update Embedded, but didn't work. To make mine work, I had to do:
Tools -> Network -> Uncheck "Add proxy server configuration to Git/Mercurial". Hope this helps someone.
Ozan Bayram September 22, 2018
I preffer System Git, so it's always up to date not having a problem like this.
Vijaykumar Murlidhar Tanwani
July 23, 2018
Below steps I followed to fixed the issue.
go to -> Tools -> Options -> Network -> Security Protocol Settings -> checked Enable TLS 1.2 option.
and retry cloning.
sunk818
Try Embedded Git.
My issue was that I had cygwin installed and the path was set so that cygwin binaries would execute first. The invalid path contained `/cydrive/c/` which should tell you why the invalid path occurred. Not sure if SourceTree needs to use explicit paths all throughout when it is not using Embedded Git.
I'm reluctant to use SourceTree with all the usability issues and bugs, but I must since we have Bitbucket Server as our repository. :(
tofutim November 20, 2013
I just got this issue checking out SourceTree for a collegue (usually just use cmd line git). Kind of an embarrassing way to start things off!
AgentSmith
November 12, 2013
