GET Calls to the API method /2.0/repositories/{workspace}/{repo_slug}/pipelines/{pipeline_uuid}/steps/ fail with a 400 for the following reason:
{"error": {"message": "Bad request", "detail": "Unexpected response body", "data": {"key": "unexpected.response.body", "arguments": {}}}}
I have verified that my workspace, repo_slug, and pipeline_id are correct, twice.
The message of this error also doesn't seem to refer to anything you'd use in a GET call.
Please let me know what you can.
Hi @Adam Leppek
Just to confirm did you use the bracket for the pipelines UUID? It needs the bracket to works otherwise you'll receive the error.
An example call:
https://api.bitbucket.org/2.0/repositories/<workspacek>/<reponame>pipelines/{53d53b0c-9a68-4fbb-b6b5-81bd5e2946a0}/steps/
Let me know if it's still failing after you added the bracket for the pipeline UUID.
Syahrul
Hi @Adam Leppek
Noted, I am leaning towards the URL encoding. Can you try removing the bracket in the URL and replacing it with the following encoding:
{ = %7B
} = %7D
As an example below:
curl --request GET --url https://api.bitbucket.org/2.0/repositories/api-public-test/api-test/pipelines/%7B1fdc2f3b-d421-41d3-ae75-f43dea9524e4%7D/steps/
I hope this helps.
Syahrul
@Syahrul I replaced the brackets with the encoded version, and everything now works. Thanks a lot for helping out with this.
