We have many people working and creating PR against develop branch.
Sometimes happen the following:
PR A is open, it add some code that call f(), pipeline build is OK
PR B is open, it add a parameter to function f(), pipeline build OK
PR B is merged in develop, develop is OK
PR A is merged in develop, develop FAIL
This could be prevented if after merging PR B, all open PR against Develop would be rebuild.
I know this is going to increment a lot the "cost" in pipeline for each merge, BUT is a little price I'm willing to pay to avoid Develop break.
Pretty sure bitbucket does not have a nice way to do it, but im open to script/api trickery
Pipelines run on push or when manually triggered, to achieve what you're trying to do I would suggest changing the workflow of your team and make sure that before merging branch is up to date with develop.
This could be achieved after merging PR A either by rebasing PR B on top of develop or merging develop to PR B. This could be done through UI by clicking on the Sync button for the branch PR B as in the screenshot below.
Any of those actions would trigger new pipeline.
Peter
Thank you,
This is pretty much what i was looking for,
is there a way to disable merge (or display a warning) if not in sync with the target branch?
I want to make the process as foolproof as possible
