×is it possible to resolve an issue and change the assignee at the same time, at the moment i first resolve, then after refresh i open edit and change assignee back to reporter,
any suggestions ?
I'm not sure I understand. You can certainly make a rule in your workflow that both resolves an issue and sets the assignee. Or you can bring up a screen that will ask you what the resolution is and also allow you to reassign the issue.
I'm not clear what you want to do. Can you restate?
