scp-deploy asterisk not working
aeris_alex
February 23, 2021
The documentation states that
LOCAL_PATH: '${BITBUCKET_CLONE_DIR}/*'    # copy the contents from the current directory.
However if I use an asterisk I get an error
/opt/atlassian/pipelines/agent/build/*: No such file or directory
It works fine without the asterisk but I get the build folder created on the remote machine which isn't something I want. Am I missing something?
Sorry it's lost the indentation when I've pasted it
image: atlassian/default-image:2
pipelines:
default:
- parallel:
- step:
name: Deploy artifacts using SCP to PROD
deployment: staging
script:
- pipe: atlassian/scp-deploy:1.0.0
variables:
USER: $user
SERVER: $server
REMOTE_PATH: '/usr/share/nginx/connect'
Halyna Berezovska
April 5, 2021
@aeris_alexnow you can use updated version, try, please 1.0.1 .
Looking forward to see your feedback!
Halyna Berezovska
March 24, 2021 edited
@aeris_alextry as a workaround for now
LOCAL_PATH: '.'
I guess, for current directory it is working differently. We will investigate more and update documentation appropriately .
Also, I think this is a bug. We'll notify you about the fix and doc update also.
Regards, Galyna
Oleksandr Kyrdan
February 26, 2021
Hi @aeris_alex ,
Thank you for your question!
We'll investigate this case and notify you.
Best regards,
Oleksandr Kyrdan
