settings.xml configuration on Pipelines
phillipsbryanj November 21, 2016
How do I specify the settings.xml file location for Maven on Bitbucket Pipelines?
phillipsbryanj February 6, 2017
If you place a settings.xml file in the $HOME directory on your docker instance, it will be used to run your maven commands.
pipelines:
  default:
    - step:
        script:
          - cp <repo-path>/settings.xml $HOME/.m2/settings.xml
          - mvn clean install
John Hall February 7, 2017
This worked for me when I replaced
<repo-path>
with
/opt/atlassian/pipelines/agent/build
Natarajan Kuppan
July 17, 2019
any one know, what is the $HOME path here?
5 votes
64BitChris
October 30, 2018
I'm late to this conversation but I wanted to point out that the accepted answer here seems to imply that the maven credentials are stored in a settings.xml file in the source code repository.
This is a security risk as you should never store credentials in source code repos.
Instead, you should store your credentials in BitBucket Pipelines Secure Environment Variables and then substitute them into a settings.xml file during your build step.
We created a guide that demonstrates how to do this as part of getting pipelines setup with maven repositories in a professional, secure manner.
For anyone coming along seeking an example please check it out:
Continuous Integration: A Complete Guide to Using BitBucket Pipelines With Maven Repositories
Good luck!
Francisco Johnatan
December 16, 2020
Hello, I'm having the same problem. None of the above solutions helped me
Natarajan Kuppan
July 17, 2019
Hi ,
John Hall February 6, 2017
Oh, thanks @Bryan Phillips, this is awesome. Can you add this as an answer?
@Bryan Phillips,
That's how you update settings.xml in your local Maven repo, but we are talking about the remote settings.xml file that Bitbucket uses on the docker container when running mvn commands. At this point, I am guessing that the this files is a part of the maven:3.3.3 docker image listed in bitbucket-pipelines.yml
I just copied the settings.xml file from my repo to the home directory before building.
cp <project-path>/settings.xml $HOME/.m2/settings.xml
mvn clean install
John Hall February 2, 2017
Yes, we'd like to know how and specifically need to be able to configure the `<servers>` element with authentication info
