Hi Everyone,
When ı want to connect via ssh, sometimes ı can connect sometimes can not.
Do u have any suggestion?
Best Regards
Hi Fatih,
We have deprecated some of the IP addresses that were previously used by Bitbucket Cloud. The IP that your server is trying to connect to, 104.192.141.1, is one of these IPs.
You can find a list of IPs currently used by Bitbucket and also deprecated ones here:
Can you check the hosts file on this server and look if there are any entries that map bitbucket.org to a certain IP? If so, can you please remove these entries, save the file, and then try the operation again, so that your DNS resolves the domain name?
Theodora
We recently started facing the connection reset error while running pipeline. I have updated the hosts.allow file with the IPs mentioned in the url provided.
Unfortunately the issue is not resolved. It's showing the same error.
PS: Removing all lines from hosts.deny solves the problem temporarily.
