ssh-run: running script on remote server hangs
aslane November 2, 2021 edited
Hello -
I am trying to configure a bitbucket pipeline using a runner to run on an AWS EC2 instance. I have the runner up and running via the command supplied when creating the runner.
I came across the ssh-run pipe and thought that might be a good solution for this task, especially because a lot of the examples have ec2-user as SSH_USER.
I want to configure a simple git pull command on the ec2 instance, yet the pipeline just hangs at `ssh -A -tt -i /root/.ssh/pipelines_id -o StrictHostKeyChecking=no -p 22...`
Here is the pipeline yaml file along with the script it is attempting to execute.
image: atlassian/default-image:2
pipelines:
default:
- step:
runs-on: self.hosted
script:
- pipe: atlassian/ssh-run:0.3.1
variables:
SSH_USER: 'ec2-user'
SERVER: <ec2 IP addr>
MODE: 'command'
COMMAND: <script on ec2 instance>
script (on the ec2 instance):
#!/bin/bash
git -C <path on ec2 instance> pull
Thank you.
EDIT:
just a silly ssh/bitbucket auth issue...works as expected now.
Igor Stoyanov
November 5, 2021
@aslane  hi. So do you solve you problem? If yes, consider to move your edit comment as separate response and mark it as answered.
Regards, Igor.
atlassian, atlassian community, job interviews, interview tips, career advice, interview preparation, job search, interview experiences, hiring process, atlassian careers, community discussion, interview best practices
Interview Tips & Pet Peeves ✍️
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!
