The URL you are using seems to be an HTTPS URL and not SSH.
Your SSH URL should like this: git@bitbucket.org/ultimategamingchampionship/website.git
or like: ssh://git@bitbucket.org/ultimategamingchampionship/website.git
Hi Erez,
Thank you. Where did you find the reference on how to construct the SSH URL? Your first suggestion works, the second one does not. Any ideas why ?
Many thanks!
Hi I'm on MacOS Monterey, using bash to run git clone to clone a repo. I've created a private/public keypair of ssh keys for this purpose. I installed the .pub key into my Personal Settings on Bitbucket.org.
I followed this guide to setup ssh keys for bitbucket on my local Mac: https://support.atlassian.com/bitbucket-cloud/docs/set-up-personal-ssh-keys-on-macos/
Ssh version is:
ssh -V
OpenSSH_8.6p1, LibreSSL 3.3.6
My .ssh/config file has:
ServerAliveInterval 90
Host bitbucket.org
AddKeysToAgent yes
PreferredAuthentications publickey
IdentityFile ~/.ssh/<keyname>
When I use this URL (what I think is the SSH URL) I get this output:
Michaels-Mac-Pro:UGC code, assets MGW$ GIT_TRACE_PACKET=1 GIT_TRACE=1 GIT_SSH_COMMAND="ssh -vvv" git clone https://git@bitbucket.org/ultimategamingchampionship/website.git
10:30:39.891919 exec-cmd.c:139 trace: resolved executable path from Darwin stack: /Applications/Xcode.app/Contents/Developer/usr/bin/git
10:30:39.892569 exec-cmd.c:238 trace: resolved executable dir: /Applications/Xcode.app/Contents/Developer/usr/bin
10:30:39.892882 git.c:460 trace: built-in: git clone https://git@bitbucket.org/ultimategamingchampionship/website.git
Cloning into 'website'...
10:30:40.172016 run-command.c:654 trace: run_command: git remote-https origin https://git@bitbucket.org/<workspace>/website.git
10:30:40.177111 exec-cmd.c:139 trace: resolved executable path from Darwin stack: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core/git
10:30:40.177698 exec-cmd.c:238 trace: resolved executable dir: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core
10:30:40.178239 git.c:749 trace: exec: git-remote-https origin https://git@bitbucket.org/<workspace>/website.git
10:30:40.178265 run-command.c:654 trace: run_command: git-remote-https origin https://git@bitbucket.org/<workspace>/website.git
10:30:40.182849 exec-cmd.c:139 trace: resolved executable path from Darwin stack: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core/git-remote-https
10:30:40.183364 exec-cmd.c:238 trace: resolved executable dir: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core
10:30:40.602217 run-command.c:654 trace: run_command: 'git credential-osxkeychain get'
10:30:40.611189 exec-cmd.c:139 trace: resolved executable path from Darwin stack: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core/git
10:30:40.611831 exec-cmd.c:238 trace: resolved executable dir: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core
10:30:40.612383 git.c:749 trace: exec: git-credential-osxkeychain get
10:30:40.612404 run-command.c:654 trace: run_command: git-credential-osxkeychain get
Password for 'https://git@bitbucket.org':
When I try the HTTPS clone URL I get:
Michaels-Mac-Pro:UGC code, assets MGW$ GIT_TRACE_PACKET=1 GIT_TRACE=1 GIT_SSH_COMMAND="ssh -vvv" git clone https://gwhizofugc@bitbucket.org/<workspace>/website.git
10:43:44.044604 exec-cmd.c:139 trace: resolved executable path from Darwin stack: /Applications/Xcode.app/Contents/Developer/usr/bin/git
10:43:44.045203 exec-cmd.c:238 trace: resolved executable dir: /Applications/Xcode.app/Contents/Developer/usr/bin
10:43:44.045703 git.c:460 trace: built-in: git clone https://gwhizofugc@bitbucket.org/<workspace>/website.git
10:43:44.610387 run-command.c:654 trace: run_command: git remote-https origin https://gwhizofugc@bitbucket.org/<workspace>/website.git
10:43:44.615415 exec-cmd.c:139 trace: resolved executable path from Darwin stack: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core/git
10:43:44.616041 exec-cmd.c:238 trace: resolved executable dir: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core
10:43:44.616577 git.c:749 trace: exec: git-remote-https origin https://gwhizofugc@bitbucket.org/<workspace>/website.git
10:43:44.616601 run-command.c:654 trace: run_command: git-remote-https origin https://gwhizofugc@bitbucket.org/<workspace>/website.git
10:43:44.622374 exec-cmd.c:139 trace: resolved executable path from Darwin stack: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core/git-remote-https
10:43:44.622924 exec-cmd.c:238 trace: resolved executable dir: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core
10:43:45.024435 run-command.c:654 trace: run_command: 'git credential-osxkeychain get'
10:43:45.044009 exec-cmd.c:139 trace: resolved executable path from Darwin stack: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core/git
10:43:45.044639 exec-cmd.c:238 trace: resolved executable dir: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core
10:43:45.045211 git.c:749 trace: exec: git-credential-osxkeychain get
10:43:45.045233 run-command.c:654 trace: run_command: git-credential-osxkeychain get
Password for 'https://gwhizofugc@bitbucket.org':
If I run:
ssh -T git@bitbucket.org
authenticated via ssh key.
You can use git to connect to Bitbucket. Shell access is disabled
I don't think I should need to enter any passwords. If I enter the password anyway to the above prompt, I get:
10:45:56.463192 run-command.c:654 trace: run_command: 'git credential-osxkeychain erase'
10:45:56.472239 exec-cmd.c:139 trace: resolved executable path from Darwin stack: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core/git
10:45:56.472858 exec-cmd.c:238 trace: resolved executable dir: /Applications/Xcode.app/Contents/Developer/usr/libexec/git-core
10:45:56.473356 git.c:749 trace: exec: git-credential-osxkeychain erase
10:45:56.473375 run-command.c:654 trace: run_command: git-credential-osxkeychain erase
remote: Login failed due to incorrect login credentials or method.
remote: If you are unsure of which login details or login method to use, visit:
remote: https://support.atlassian.com/bitbucket-cloud/docs/log-into-or-connect-to-bitbucket-cloud/
fatal: Authentication failed for 'https://bitbucket.org/ultimategamingchampionship/website.git/'
