Hi team,
Is it possible to setup the pipeline using git commands, it should deploy into the AWS instance after git push. ?
If yes can you please give me the reference url's.
Present i have setup the pipeline using below configuration:-
image: "node:10.15.0"
pipelines:
branches:
development:
step:
deployment: test
name: "install and build"
caches:
- node
script:
- "apt-get update -y"
- "apt-get install -y zip"
- "cd admin/front-end"
- "npm install"
- CI=false
- "npm run build"
- "zip -r /tmp/artifact.zip *"
trigger: automatic
artifacts:
- admin/front-end/build/**
step:
image: "python:3.5.7"
caches:
- pip
script:
- "pip install boto3==1.9.197"
- "python codedeploy_deploy.py"
Regards,'
Venkat.
Learn why Compass was built to tackle dev experience at scale. See how Atlassian uses it to boost visibility, reduce cognitive load, and drive consistency—plus tips to get started and customize your IDP for stronger team engagement.
Join the webinar ✨Online forums and learning are now in one easy-to-use experience.
