why every push is executing below commands in the server?
99099 28334 7928 0 17:40 ? 00:00:00 /usr/local/git/bin/git receive-pack /opt/atlassian-shared/bitbucket/data/repositories/86
99099 28356 28334 0 17:40 ? 00:00:00 git gc --auto --quiet
99099 28358 28356 2 17:40 ? 00:00:07 git reflog expire –all
As the repository size is around 10 GB, it is running for hours. When the same person pushes again, another instance of these three commands are initiated again against same directory.
After some time:
Still running
99099 28356 1 0 17:40 ? 00:00:00 git gc --auto --quiet
99099 28358 28356 2 17:40 ? 00:00:21 git reflog expire –all
Another instances running for next push
99099 31719 7928 0 17:55 ? 00:00:00 /usr/local/git/bin/git receive-pack /opt/atlassian-shared/bitbucket/data/repositories/86
99099 31736 31719 0 17:55 ? 00:00:00 git gc --auto --quiet
99099 31739 31736 1 17:55 ? 00:00:02 git reflog expire --all
Is it possible to disable this behavior ? It slows down the total bitbucket performance.
Even after sometime… still two instances are running against same directory on same server. Same commands are running on all the nodes in the cluster for this shared directory.
[root@XXXXXXX ~]# ps -ef | grep git
root 770 28845 0 18:01 pts/1 00:00:00 grep git
99099 28358 28356 2 17:40 ? 00:00:26 git reflog expire --all
99099 31736 1 0 17:55 ? 00:00:00 git gc --auto --quiet
99099 31739 31736 2 17:55 ? 00:00:08 git reflog expire --all
Because of this issue, users are getting below error:
git push origin --delete feature/XXXX-10636-rank4-update-tps-of-control-advisor
Connection reset by 16.126.51.150 port 7999
fatal: The remote end hung up unexpectedly
error: error in sideband demultiplexer
To ssh://XXXX:7999/xXX/XXXXXX.git
- [deleted] feature/XXXXX-10636-rank4-update-tps-of-control-advisor
error: failed to push some refs to 'ssh://git@XXXXXXXXXXXXXXXXXX:7999/XXX/lXXXXXX.git'
FYI.. As advised by Atlassian, executed below command to reduce the loose objects.
git repack -Adln —keep-unreachable
Here is output of objects count after executing the above command.
warning: garbage found: objects/pack/tmp_pack_Nm1Etf
warning: garbage found: objects/pack/tmp_pack_IeALmi
count: 10360
in-pack: 3991287
packs: 10
size-pack: 9225714
prune-packable: 0
garbage: 2
size-garbage: 63952
Version details:
Atlassian Bitbucket v4.11.0 and GIT 2.4.5
Join the discussion on interview best practices and common pitfalls. Share your experiences and learn from others in the Atlassian Community.
Share you experiences!Online forums and learning are now in one easy-to-use experience.
