Has anyone been able to get transparency to work. In a different post, I've read that we can just use SVG, but this does not work. I've tried both SVG and PNG with transparent backgrounds, but they don't work in whiteboards. Creating good diagrams require transparency. I've attached an example to show the problem. Also, I've attached the PNG with transparent background used and the code for the same in SVG is also below. Transparency is not working.
<svg width="88" height="86" viewBox="0 0 88 86" fill="none" xmlns="http://www.w3.org/2000/svg">
<path d="M87 73C78.3333 85.3333 49 99.2 1 56L33 1L87 73Z" fill="url(#paint0_linear_3_2)" stroke="black"/>
<defs>
<linearGradient id="paint0_linear_3_2" x1="19" y1="37" x2="44" y2="85.3417" gradientUnits="userSpaceOnUse">
<stop stop-color="#E52E2E"/>
<stop offset="1" stop-color="#7F1A1A"/>
</linearGradient>
</defs>
</svg>
Thanks @Yatish Madhav , were you able to find a way to create your own stickers and stamps? If one could do that, then at least there is a temporary workaround. I looked at the stickers and stamps, but as you say, they are very limited and does not include typical software engineering icons and elements.
Unfortunately not, @Jack - I only ended up making use of the stickers and stamps in creative ways, since I also have a design background. Ideally, it would be great if we can simply upload our own PNG/GIF/SVGs.
Sorry for the not-so-helpful answer.
Thanks, much appreciated. Let's hope Atlassian responds. Hopefully they have a solution or temp workaround.
We also have a lot of problems returning whiteboards from other products like MIRO. This feature is important for design communities (UX/UI) and for teams more focused on WEB
@Jack unfortunately not! :(
