Hi Atlassian Community 👋 I’m Rory, a Product Manager from the Atlassian Editor team.
I’m excited to share a number of recent changes we’ve recently started rolling out for Confluence tables.
With the rollout of custom table widths in 2023, we introduced the flexibility to set tables to any custom width in both fixed-width and full-width Confluence pages. Since then, we’ve heard from many of you about the need for more table alignment options, especially for use within full-width pages.
With this change you can now use the tables floating toolbar to align your table left or center.
ℹ️ Note: We’ve also updated the default setting for tables inserted in full-width pages to be left-aligned.
We've made table scaling behavior consistent across edit and view modes, and increased the threshold before a table breaks into a horizontal scroll. This should provide a simpler experience, as well as better support for tables viewed in smaller viewports.
↔️ Table scaling logic: tables will scale down proportionally to a point before breaking into a horizontal scroll - providing some flexibility for viewing tables on smaller screens while preventing excessive narrowing of columns where content becomes unreadable.
We've added a full-width option! To set a table to full width, use the table resize handle to snap it to the guide near the edge of the page. Tables set to full width will span the width of the page regardless of viewport size; however, they will follow the scaling logic outlined above.
ℹ️ Note: We’ve also updated the default setting for tables inserted in full-width pages to be full-width.
To scale or not to scale, that is the question!? Now you can choose when you want to use fixed columns or scalable columns.
👻 Tip: Fix your column widths by selecting 'Fixed column widths’ in the options menu in the table floating toolbar.
When you select fixed column widths, you have absolute control over your column widths and table formatting, ensuring that your content’s structure will always be viewed in its original, intended state.
In contrast, with the default setting, you allow your columns to scale and give your content more flexibility to adjust and fit into a variety of screen sizes.
How to configure 'Fixed column widths'
The result - columns remain fixed instead of scaling down
Do you have a table with lots of colored cells? Do you wish that your color from the adjacent column would automatically be applied to any new columns that you add? Well, now they do.
We hope you are loving Confluence tables more and more!
Please let us know what you think or ask any questions in the comments below - we would ❤️ your feedback.
Rory Baker
Senior Product Manager - Editor
3 accepted answers
16 comments
