Integrating Confluence and Jira creates a cohesive environment where project tracking and document management enhance each other perfectly. This integration allows teams to streamline their workflows, improve collaboration, and maintain comprehensive documentation.
Connecting Confluence and Jira
To connect Confluence with Jira:
Tracking Issues in Confluence
You can track Jira issues directly in Confluence by pasting your Jira link on a Confluence page. Once you publish the page, it will display:
Alternatively, use the Jira Issues Macro:
Whenever an issue is mentioned using the Jira Issues macro, it automatically creates a link back to that page in Jira.
Sharing Reports Using Smart Links
Confluence allows you to share reports using data from Jira:
Use Smart Links for embedding these elements directly into a Confluence page for context-rich progress reports and status updates.
Automation with REST API
Leverage automation by integrating with the Confluence REST API:
This ensures seamless linkage between project documents and tasks without manual intervention.
Integrating Confluence with Jira enhances productivity by combining robust project tracking with comprehensive documentation capabilities ensuring all stakeholders are aligned throughout every phase of delivery.
Sushant Verma
Consultant
Genpact India Pvt. Ltd.
India
133 accepted answers
0 comments
