We’re so excited to announce that we have started rolling out Confluence whiteboards to all Confluence customers! This new tool is designed to enhance your team's collaboration, allowing you to visually map out ideas, plans, and projects in a dynamic and interactive way 🤩
Confluence whiteboards will be progressively rolled out to customers in the coming weeks. Customers requiring import/export functionality will receive Confluence whiteboards at a later date as we build out functionality to support these requirements. Admins of these sites can choose to bypass this requirement and self-opt into Confluence whiteboards in the admin hub.
With Confluence whiteboards, your team can freely express and explore ideas without the constraints of traditional formats. It serves as a canvas for your creativity, allowing you to jot down notes and move elements around as your ideas develop.
Your whiteboard toolkit
Add sticky notes, shapes, lines, and stamps to your board! Or start a timer for your latest team collab session. Confluence whiteboards give you the tools for whatever you’re trying to accomplish – from small team brain dumps to running large plays with cross-functional teams.
Learn more about the tools in Confluence whiteboards.
Use templates to get started
From planning to brainstorming to running retrospectives, Confluence whiteboards come with a bunch of best practice templates making it easy for you to get started.
Learn more about templates in Confluence whiteboards.
Collaborate with your team
Bring your team along! Whiteboards are the perfect canvas for teamwork. Invite others to your board and collaborate in real-time.
Transitioning from brainstorming to execution is seamless with Confluence whiteboards. Its close integration with Jira (Jira Software, Jira Work Management, Jira Service Management, Jira Product Discovery) allows you to move your work from an idea on a sticky into an actionable task with a few simple clicks. Convert sticky notes into a Jira issues, create relationships between issues, and apply actions to issues in bulk without ever leaving your whiteboard.
Learn more about Confluence whiteboards and Jira.
Transform a sticky into an action item
Learn more about converting a sticky into a Jira issue.
Create relationships with smart connectors
Learn more about smart connectors.
Take actions in bulk with smart sections
Learn more about smart sections.
Avoid interruptions caused by disconnected apps for increased efficiency and reduced context switching. Embed 3rd party links directly onto your whiteboard so you can easily access information from anywhere on a single screen.
Learn more about inserting links in Confluence whiteboards.
Or, embed your whiteboard into pages and other Atlassian tools for a more comprehensive view of your work.
Learn more about embedding whiteboards into Atlassian tools.
Consolidate tools
Confluence Whiteboards brings together the best visual collaboration tools in one place, reducing the need to switch between apps and platforms. Whether you're mapping out a project timeline, organizing a sprint, or planning a product launch, everything can be done within Confluence.
Learn more about Confluence plans.
Get ready to take your team's creativity and productivity to the next level with Confluence Whiteboards.
Christina Ristevski | Confluence whiteboards product manager
Christina Ristevski
Product Manager, Confluence databases
Atlassian
13 accepted answers
See inside
13 comments
