đź“Ł End Users Can Now Easily Leverage Automation for Confluence with Smart Buttons
:wave: Avinoam from Confluence Automation here with an exciting new feature to make it easier for end users to use Automation for Confluence.
With smart buttons, end users on Confluence Premium and Enterprise plans are now able to create their own rules from a pre-defined list and run the automation with a click of a button on the page. This helps admins and users save time by safely placing automations in the users' hands, with the right guardrails. Let’s dive in!
Why smart buttons?
We know being an admin isn’t easy, especially when juggling multiple requests across spaces, assigning new users, and more. Smart buttons helps reduce the admin burden by allowing users to set up and launch one-time automation rules on a specific page.
It’s a win-win for all: admins get time back to focus on other high priority work, end users can eliminate low-value manual tasks, and everyone benefits from the clearer processes that smart buttons enable.
Here are some example use cases
  • Create a “Send for approval” smart button on a creative brief: Once clicked, it will change the page status to “ready for review” and send an email to reviewers with a request to approve the details.
  • Create a “Notify team members” smart button on a marketing launch plan: Once clicked, it can update page restrictions so cross-functional partners can access the plan and send an email to share it with them.
  • Create a “Kick off next steps” smart button on a product poster page: Once clicked, it can add a label for the new product and create new page templates for product requirements, product design, and technical documentation to be filled in by the team.
How do smart buttons work for admins?
Admins are always informed and in control
Admins will be able to view and manage all smart button automations in Global automation or Space automation. These automations will be identified by a smart button label, and admins will be able to view it in the rule builder, as well as disable it as needed. They’ll also be able to see page details in the audit log to see where the smart button was triggered.
How do smart buttons work for end users?
End users with edit permissions can create and edit smart buttons on a page
When ready to add a smart button in edit mode, end users can select the insert menu (+ icon) from the toolbar or type /smart button or and select “smart button.” From there, the end user can choose from a pre-defined list of automation templates and edit the components to fit their use case.
End users can click the smart button to execute one-time actions
Anyone with view permissions on a page can hover their cursor over the smart button to see what actions it’ll take. When a user clicks the smart button, it’ll trigger the actions in sequence, respecting the permissions they’ve been assigned. For example, a user who has edit access can successfully run a smart button to change a page’s status and update its labels. However, a read-only user will still not be able to change the page’s status or labels, even through the smart button. This helps set safeguards in place and control who has access to run the automation.
FAQs
When will it be available?
It's currently rolling out gradually to all Confluence Premium and Enterprise admins and their users!
How should I get started?
Admins can work with power users to help identify the top use cases and guide them through the first smart button setup. Questions to ask would be: Are there any workflows that require repetitive manual tasks? What tasks are involved (e.g. notifying team members, adding a label, updating page status)? What type of pages are typically involved?
How is smart button usage measured?
Only smart button usage that successfully takes an action will count towards your overall automation usage. Admins can manage automation usage by determining which users can create automations, as well as by monitoring top-running rules from the Automation Usage tab. Automation Service Limits will also apply across smart button usage.
How is smart buttons different from manual triggers?
Great question! Last year, we released manual triggers as our first foray to opening Automations in Confluence to end users. However, unlike smart buttons which can be created by end users directly, manual triggers need to be pre-defined and set up by admins in order for end users to trigger them.
In addition, smart buttons can be added anywhere inside a page within the context of the content, whereas manual triggers exist at the entire page level and not in context.
What’s next?
This is just the beginning of smart buttons! Over the next few months, we’ll continue to add more use cases and actions for smart buttons, including actions across other Atlassian products like Jira. We’ll also provide increased levels of visibility for admins, making it easier to manage all smart buttons built by end users.
We want to hear from you!
We’d love your feedback so please feel free to schedule time with us directly here or drop a comment on this post on how you plan to use smart buttons! :pray:
21 comments
Laurie Sciutti
July 8, 2024
đź‘Źđź’—
Like • # people like this
Hana Kučerová
July 8, 2024
Love this!
Zack Howard
Looking forward to this! Will there be an option for the button to activate an existing automation? Or will we have to set up a new automation each time the button is inserted on the page?
Avinoam
July 8, 2024
@Zack Howard down the line that's the plan - to both link from a rule to a smart button and vice versa. For the short term manual triggers are still the best vehicle for linking an existing automation :)
Svenja Lorenzen
July 12, 2024
This is brilliant and expands the possibilities of working with Confluence many times over! 👏🏻💙
Aaron Geister
July 18, 2024
This is super solid and now we can have approvals in Confluence. I have been waiting for something like this and super happy that we now have action buttons in Confluence. This is icing on the cake!! Great work @Avinoam
Alison Milne
Look forward to trying this out
Davide Giglioli
Hello, thanks for this new feature. I have two questions:
  1. can administrators define Smart Button Templates? currently the options are limited to basic options, and the "smart button" automation rules created are not editable.
  2. are the smart buttons available to customers of Jira Service Management portal?
We are trying to understand how we could allow these customers to export the page into a pfd file and have it sent to their email address, and we are wondering if Smart buttons could help for this.
Avinoam
July 24, 2024
@Davide Giglioli excellent questions!
  1. Not at this time, since we intentionally wanted to start out a bit limited and open up as we go. This is absolutely on our roadmap to open up configuration vs. only being able to use pre-defined templates.
  2. Not yet, however, they are built in such a way that in the future any product with automation at Atlassian can add them, so over time we expect these to become available outside only Confluence.
Like • Davide Giglioli likes this
Matt Reiner _K15t_
Ohhhh smart buttons, you have SUCH a bright future!
Video, of course: https://youtube.com/shorts/vCq_tIi1ALI
Like • Bri likes this
Zachary Howard
@Avinoam Hello again! I was playing with the Smart Buttons feature and was wondering if there will be a way to select "Current Page" or "Same Page as Trigger" as the value for the Parent page field.
My Use Case: I was going to use this button on a "Meeting Notes Overview" page for users to generate a new Meeting Notes page under the current page. Currently I have been using @Matt Reiner _K15t_ teams' addon called "Create From Template Pro" however, this also does not allow you to set the current page when putting it in a template.
Currently, our PMs still have to go in and manually edit the Meeting Notes Overview page (which is automatically created for them from the template w/ automations) to make the button point to the current page.
I would love to eliminate this step for our users!
Thanks y'all!
Like • Matt Reiner _K15t_ likes this
Avinoam
September 16, 2024
@Zachary Howard great call out. This state is intentional as we need to build them out separately for the main rule builder and smart buttons. That said, we're going to add these to smart buttons in the upcoming weeks, so stay tuned!
Khai Ha
@Avinoam Is there any update on when Smart Buttons can be mapped to perform a custom automation as opposed to a template?
Avinoam
September 23, 2024
@Khai Ha that should be available in a the coming months, but in the meantime we're adding more template shortly!
jd_santos
Am I understanding correctly that smart buttons can't be used to launch actual Confluence automations? Just whatever minimal functionality is provided by the templates, which aren't even customizable?
Can y'all understand how incredibly frustrating and unintuitive it is to have extremely similar functionalities here that apparently don't communicate at all? Confluence automations were launched two years ago, so this isn't even an issue of interacting with "legacy" features.
I want to push a button and launch an automation, that doesn't seem like much of an edge case.
cosmin_parnia
January 21, 2025
Hi @Avinoam ,
I believe that smart buttons have a promising future and there are numerous potential applications for such a feature.
However, the current templates for the smart button have limited functionality.
I would appreciate any updates on when custom automations can be used with the smart buttons.
Could you please provide an estimated timeframe for this feature to be implemented?
Like • Eric Dupuylolier likes this
Eric Dupuylolier
March 4, 2025
As a end user, I create a smart button but it doesn't work. How can I access to the audit log?
Bob Dalm
March 17, 2025
Great feature with lots of potential, but severely limited by the fact custom automation rules cannot be selected. In it's current form, we have no practical use for smart buttons, but hopefully anticipate the upcomign updates!
March 17, 2025
Hi @Bob Dalm
Here are some suggestions to improve the Smart Button feature, which you may watch / vote-for to see progress:
Like • Bob Dalm likes this
Bob Dalm
March 18, 2025
@Eric Dupuylolier - you can find the rule connected to the smart button in the Space's automation section as a "view only" rule with the label "Smart Button".
VINCENT DUPONT
Keep it simple! simply let the smart button use an existsting Automation with Manual Trigger.
Cancel all predefineds templates, they are useless
thanks
Vincent
