📣 Introducing Confluence Automation in Free and Standard plans + Dec 17th AMA!
👋 Avinoam from Confluence Automation here with an exciting new update - Confluence Automation is now available across all Confluence Cloud plans, from Free to Enterprise!
This allows automation to grow with you, adapting to the complexity and scale of your processes over time. Whether you’re just getting started or handling enterprise-level needs, automation rules can be expanded and refined without worrying about execution limits.
  • Free Plan: Up to 10 rule executions per instance (NEW)
  • Standard Plan: Up to 100 rule executions per instance (NEW)
  • Premium Plan: Up to 1,000 rule executions per user (NO CHANGE)
  • Enterprise Plan: Unlimited rule executions per user (NO CHANGE)
Read on to learn more about Confluence Automation and new resources for you!
What is Confluence Automation?
Confluence Automation is a powerful tool designed to help teams save time, improve productivity, and manage content at scale by automating repetitive, manual tasks. With automation, you set up a criteria or rule that automatically triggers an action when it occurs. The point of automation is to reduce the work around work 🙌
Here are some example use cases
  • Maintain a source of truth within Confluence by auto-archiving stale content or assigning labels to a new page
  • Notify teams and keep work on track by auto-sending an email or Slack notification when a task is approaching a due date
  • Power work across your favorite Atlassian tools by auto-creating or updating Jira issues from Confluence, without having to context switch across products
How do I get started?
Quickly build rules with our no-code builder and pre-built templates
With Confluence Automation, anyone on your team—regardless of technical background—can streamline workflows and eliminate manual tasks.
Admins can get started quickly by using our visual rule builder to drag-and-drop elements in to build powerful rules. You can also get started quickly with pre-built templates for common tasks, such as archiving content, assigning owners, and more – no need to start from scratch!
Manage and scale automation across your organization with ease
Admins can rest easy with full oversight and control over how automation is configured and managed across your Confluence site and spaces, ensuring you’re within your plan’s automation limit while helping your teams reduce manual work.
Admins get access to a full audit log to track every automation action to show when rules were triggered, the outcomes, and any action performed. You also get visibility into monthly automation activity, with the ability to disable or enable rules as needed.
What about end users?
End users with edit permissions can create and edit smart buttons on a page
With automation smart buttons, end users are able to create their own rules from a pre-defined list and run the automation with a click of a button on the page.
When ready to add a smart button in edit mode, end users can select the insert menu (+ icon) from the toolbar or type /smart button and select “smart button.” From there, the end user can choose from a pre-defined list of automation templates and edit the components to fit their use case.
FAQs
When will it be available?
Starting December 9th (today!), customers on Free and Standard plans can start using automation. There is no change to Premium and Enterprise plans. See the usage limits that determine how many times rules can be executed per month, depending on if you’re on a Free, Standard, Premium, or Enterprise plan.
Where can I learn more?
Here are some resources:
Have more questions? Join our Dec 17th AMA!
We’ll be hosting a live AMA on December 17th  to answer any and all burning questions about automation. Please add your questions as a comment on this post so that we can be sure to answer them during the live session!
Sign up to reserve your spot today!!
AMA – Confluence Automation Tuesday December 17th, at 9:00am PST - Register here!
14 comments
Tomislav Tobijas
Time to get that automation running on my private site 😄🥳
Like # people like this
Steven Rhodes
Yeah, this is pretty much useless on Standard but for my personal site, sure. Its a start though! Thanks Atlassian!, I guess.
Like Gabor Nagy _Midori_ likes this
Aron Gombas _Midori_
Nice, Confluence Automation team!
When you write about the quotas, like "Free Plan: Up to10 rule executions per instance", what is the timeframe? Is it 10 executions per day? Per week? Per month?
Steve Rhodes
@Aron Gombas _Midori_ the FAQ mentions plans per month:
So, yes for free plans thats 10 per month or 0.322 automations per day.
@Steve Rhodes Oh, thanks.
In my experience, when setting up an automation rule - whether for Jira or Confluence (the tool is irrelevant) - I build it gradually. I add components incrementally, testing and refining it repeatedly until it takes its final shape. Unless someone can create a rule in its perfect form on the first attempt, even the initial setup typically requires far more than 10 test runs.
A limit of 10 runs is prohibitively restrictive. 100 is a bit better, but still limiting.
Patricia Modispacher _appanvil_
Cant wait for the AMA on December 17th to learn more about how this can further enhance productivity!
Like Mindy Park likes this
Levente Szabo _Midori_
@Steve Rhodes yes, it's a start, and an improvement for Free and Standard plan users — 10 and 100 rule executions per month! 🎉
I’m curious how Free and Standard plan users are finding this update? Are 10/100 rule executions enough to automate Confluence workflows and save time? Do you have any further wishes or could use a higher limit? AMA is great to tackle questions but I guess it's not for expressing wishes and asking for more from Atlassian.
If you are a Free or Standard Confluence user, let’s hear from you!
While you share your questions for the AMA, take a second to share how you are finding this improvement! Vote on this simple Yes/No poll and use the space to tell your wishes about Confluence automation.
Vote below and add your thoughts! 👇
I'm a Free/Standard Confluence user and I think this update is ... >>>
Shahpur Khan
Will the 12/17 AMA address questions about using Rovo with Confluence Automation? Thanks in advance.
Like Avinoam likes this
Hana Kučerová
I've got a question - are there plans to add special user Automation for Confluence (similar to Automation for Jira)? I miss this possibility very much, users are confused, if actions are executed in their name, and we need to change the actor of the rule every time somebody leaves the company. Thank you.
Mindy Park
December 16, 2024
@Shahpur Khan Yes, we can! Can you share what questions you have about Rovo and Confluence Automation here? We'll make sure to address it tomorrow :)
Shahpur Khan
@Mindy Park Thanks! We mainly are trying to think of inspiration for neat ways to use Rovo with Confluence. So it would be nice to hear what you two think would be some good scenarios and use cases for Rovo in Confluence Automation. For context, we're a small team of web developers, project managers, and QA engineers maintaining websites for clients. We use Confluence to maintain meeting notes, document standard procedures, and compile links to important Google Drive/Figma/Smartsheet documentation for our client projects so they're all in one place.
Alfonso Leiva
@Mindy Park hi!
There is a question from @Aron Gombas _Midori_ that I also have.
We have a Standard plan, so what's the timeframe for the 100 executions per site?
Thanks a lot in advance!
Like Aron Gombas _Midori_ likes this
@Alfonso Leiva We established that it's a monthly limit. Not sure about you, but I think it's pretty restrictive for Free and Standard users, but there are alternatives. I was curious what Free and Standard users think about this and what "whishes" they have, so I created this survey to capture your opinion. I'd be glad if you too shared your thoughts about Confluence Automation for Free and Standard!
Like Alfonso Leiva likes this
Rilwan Ahmed
Hi @Avinoam ,
Please update the warning section of https://support.atlassian.com/cloud-automation/docs/create-automation-rules-in-confluence/ . It still says "Automation is a premium feature in Confluence".
