New! Inserting Jira issues into Confluence pages is easier than ever ✨
57 comments
Valerie Blondel
Hi there, awsome !  Thanks !
When inserting Jira issues in Confluence, could it be possible to display the Confluence pages linked to the inserted Jira issues as well ?
If I am not mistaken, we can add a column displaying the linked issues.  I would like the linked Confluence pages as well.  This would really be a game changer for us.
Thanks a lot :-)
Valérie
Harri Pentinniemi
January 29, 2024
Hi @David Michelson I have made pages for our external customers and the links not working. It's working inside our company, but not for external users, so should we give rights for the customer to use Jira or what can be the problem?
Stefano
Being able to EDIT issue fields from the table would be a GREAT improvement.
Like Amy Cheong likes this
Lisa FW February 7, 2024 edited
I like where this is going. I see 2 "cons" that must be fixed before we can adopt this new macro from legacy:
  • text wrap (that others have mentioned)
  • multi-text fields with wiki style render aren't displayed correctly (edit: I now see others have mentioned this missing feature as well)
Looking forward to those updates to start converting over to this new macro!
Kevin Paugam
It's a pity that this change was not part of a bundled track. We discovered it recently only while trying to use the "legacy" /jira macro...
By the way, this change is very confusing for our users since we used to manage lot of tables with /jira legacy macro. Is there any plan to deprecate this legacy macro at one point in time? If yes, what will be the behaviour for all pages already containing the /jira legacy macro?
Otherwise, we found that tables generated with this new /jira issues macro are not correctly exported in PDF or Word documents, whether using the standard "Export to PDF/Word" or when using our "Scroll PDF Exporter" plugin. This is really a concern for us, especially when these tables are embedded in Confluence pages used as regulatory records. Do you know if there are any plans to resolve this export issue?
Like 3 people like this
Paul Palasti
Great, but what if you do not want to have the table eat up all your real estate in you document.
Is the old macro still available that allows you to insert the JIRA Issue value only?
Like Carmen Parra likes this
Lilian
We just migrated to the cloud and we have several statuses...if there was a way to 1) format the color of the status lozenge, that would be great. Right now we have two statuses with the same color. 2) would be great if we could format the date timestamp. We just need the date.
Stéphane Moser
March 12, 2024 edited
I can see 2 another cons:
  1. to this new Jira Issues macro. In the Jira legacy, we can set how many results we want to display by default, this settings seems not available in the new Jira Issues macro.
  2. the re-size to the max width seems not to work properly. We can see here that the expand is more on the left than the Jira issues filter that is just below
    Here in page edit mode we see that I cannot put more width to it
Question
Is it in the future features pipeline to be able to use "Insert Chart" table feature with this new Jira Issues macro?
Like Marina Laysha likes this
Mary-Ann Soutar
March 14, 2024
Great tool however content that is formatted in JIRA like bullet points or paragraphs doesn't pull through to confluence neither do images.
Justin Adams
March 19, 2024 edited
Wrapping text is a must for this feature. We relied on this functionality to simplify status updates. Please bring back text wrap.
Like 2 people like this
Jussi Nousiainen
March 26, 2024
Hi, this is great. Just one question, I created filter for all service management issues, but the table does not show the Project. The column is totally empty. We have several customer service portals. Is this a bug or just one of the Jira oddities?
Alison Paddock
This is a good macro inline or in the UI and I was very happy to see the text in the tables is larger and legible when you export to PDF, however looking closer at the PDF for me there are 3 issues:
  1. The table only shows the first 10 issues in the list and there doesn't seem to be way to change this so you can see the full list in the PDF version. The legacy macro shows 10 per view in the UI that you can page through and in the PDF version the full list is printed.
  2. There is no word wrap in the table lines - this is both in the UI and PDF as mentioned above
  3. The table cuts off columns in the PDF even if it only has a few.
Thank you for your time looking at this
Like Joerg likes this
James Traxler
When you want to include a Jira issue's description field, you can set the 'Wrap text' option on the field by clicking on the 'Description' header. However, you only get the first two lines of the Jira's description, and they don't retain their newline between them. Any thoughts on this?
I tried continuing to use the Jira Legacy Issue macro, but when I include the description field in that, any  inline images in the description get blown up to a very large size that makes the overall Confluence page unreadable.
The reason for including the description field, in my case, is that I want to show the detail of the story (issue ticket) in Confluence as documentation of a feature.
Like Dmytro G likes this
Erdir Ungan
April 19, 2024
AFAIK This is only available to bring issues from Jira Cloud.
We get issues on report pages from both Jira Cloud and Server Instances. The legacy macro was available before so we could use them in junction. But now I see the legacy macro's UI has been updated and unfortunately it's unusable. Selecting columns from a loooong list and any wrong click deletes the whole list. It needed some update but definitely not this one.... Is it possible to use the old version somehow?
Thanks.
Dorthe Knight May 15, 2024 edited
I am using Confluence Cloud and Jira Server.
Understanding that the Legacy editor in Confluence is being decommissioned (no date received from Atlassian as yet). I am trying to replicate Jira reports in Confluence new editor and I have seen challenges:
  • The settings in the legacy editor are not supported in the new editor.
  • Using the Table Transformer in the Table Toolbox to merge and transform two Jira tables. The SQL does not read the columns being returned by by T1 and T2.
  • Work around.
    • Using the Table Toolbox Jira filter T1 is nested inside a Table excerpt and Jira filter T2 is nested inside a second Table excerpt.
    • The two excepts are then lifted by Table Excerpt include (not part of the Table Toolbox) and included into the Table Transformer in the Table Toolbox to then allow for the merger and transformation.
Are there any plans of any improvement as I am currently facing a weeks additional work load to rewrite multiple pages.
Correction
Upon further testing I do not need to use the excepts. However, I do have a challenge when I have Jira filters returning a lot of rows that it becomes a challenge inside the Table Transformer to move from one Jira filter to the other.
In the legacy we do not see the full list but just an image.
Stiltsoft support
May 16, 2024
Hi @Dorthe Knight ,
The Table Filter, Charts & Spreadsheets for Confluence app that you are referring to is our add-on.
We are a little bit confused by your description and ask you to refer to our support where you'll be able to share your screenshots for a better guidance.
Meanwhile, let me explain that the Table Toolbox macro is a special shell to nest different macros like you do it in the Legacy editor.
You don't need any Table Excerpt/Table Excerpt Include macros to reuse you Jira macros: you just insert the Table Toolbox macro, place your mouse cursor inside its body and insert one or several Jira Issues macros on the page. Your Jira macros are wrapped in the Table Toolbox macro.
Then you open the Table Toolbox macro settings and on the left panel you'll see your Jira tables and a bunch of our macros that you can easily arrange in various combinations. For example, wrap all your Jira tables in the Table Transformer macro and then place the Table Filter macro on top.
For example, on the screenshot below I have a manually created table subsequently wrapped in the Pivot Table and Chart from Table macros:
Marina Laysha May 17, 2024
The configuration for the number of rows to display is still not available. For me the new Jira Issues macro  always displays all records, and I have over 30 that take a lot of space on the page.  I just want to display the first 10 rows.
This is the biggest feature missing from my perspective and the top priority to fix.
Thorben Egberts
June 25, 2024
Looks great! I agree that wrapping texts are a must... We use it to bring (long text) jira contens to confluence without duplicate content.
Douglas Bain
This does not work.
Our primary use case for the linkage of JIRA issues within a Confluence document is for the production of Release Notes.  For obvious reasons we want Release notes to reflect the version of the release at the time the release notes are generated.  This means we either output them to PDF or Word.  Neither outputs work.  This means that the ability to 'freeze' a confluence page is now gone, so Confluence cannot be used to record validation documentation.
That said, with the lack of wrapping support, this is an improvement. The manifestation in export is required in order for it to be useful as a replacement for the legacy macro.
Mike Low July 23, 2024
Has a change been raised to cover the wrapping issue? Would love to see this developed as to help improve the view of our release notes.
Like Stephan Grubbe Sølby likes this
Adrienne Gehannin
July 25, 2024
Hi, @David Michelson
it seems there's a problem with the toolbar at the bottom of the Jira Issues panel.
I can't edit the component anymore. The pencil button is missing.
Thanks for your answer,
Like apriscan likes this
Tony Gilchrist August 20, 2024 edited
This is great!  But... is there any way to do it from the draft page, instead of the published one?
We really want to allow readers to insert jira tickets on the draft (so they can request changes or updates to the page) without the issue link appearing on the published page.
apriscan September 4, 2024 edited
This seems nice, but in Cloud Jira/Confluence I'm using, there is no way to edit this new Jira issues table once it is placed on the page.
There is no pencil (edit) button to click on.
My primary use-case is inserting a link to one specific issue as an inline link when doing minutes.
Thus I provide the issue-key as input, but more than often I get 2+ results?! See attachment for an example (i left it on "list" to better visualize the problem), where I input MGR-1115, but get MGR-1115 and MGR-1113 as results. In this case, I can't even filter to force the result to the expected singleton.
Also the default is always List. I would prefer a setting somewhere allowing me to have Inline Link as default.
I can revert to the legacy option which does not have this problem!
Andres Oss September 17, 2024
Just like in https://community.atlassian.com/t5/Confluence-articles/New-Inserting-Jira-issues-into-Confluence-pages-is-easier-than/bc-p/2583200#M7186
Time spent is still not formatting correctly. It still shows as seconds.
Jira legacy callout is still able to handle it into human-readable format:
Learn more
