New! Inserting Jira issues into Confluence pages is easier than ever ✨
57 comments
Navira Zainab
Using Jira Issues Macro is the great experience indeed but what if it is not supported on Scroll Viewport?  It does not have much value if we can't share this experience with our customers. What does Atlassian recommend? How should we create an offline Jira report to be published for public release?
Angie Adams
This is a great improvement.  Is there any thought about allowing updates to be made to the Jira issues directly from Confluence?  Use Case:  we have a team that likes to use a filter to currate issues to review during a meeting.  It's quick and repeatable while minimizing manual effort to copy from Jira, paste into Confluence page.  They'd greatly appreciate the ability to simply click in the column for the field they need to update during the meetings rather than having to open the ticket in Jira to make the update.  In our use case, we have custom fields that need to be updated.
thanks
ljones3
November 20, 2024
Hi Jira team and brilliant minds!
We've been using the Jira Legacy module for our Release Notes, but now I'm getting a "Missing Storage Body" error.
I tried to use this new functionality, but we can't because when we export the Confluence page to PDF, it truncates the list view.
Any chance the great minds at Jira can assist?
Thank you for any help you can provide! :)
Like # people like this
Lisa FW November 20, 2024
I've opened a support ticket for the "Missing storage body". This is impacting all of our dashboards that we use daily for cross functional review. Hopefully this can be addressed asap. Thanks for any help.
Paulius Jankevicius
November 29, 2024
We finally started to transition to this new version, and we noticed another bug - if there is a Paragraph content, it's being cut short and not formatted. Just wondering, maybe there is a ticket for that here?
Example image: on the top - new list, below - Legacy list.jira-list-issue.jpg
The biggest issue is that we are worried about using the Legacy list due to increasing amount of times when it freezes in loading status (image below) and new list does not show all the data, so we stuck :(
Lucas Bienaimé November 29, 2024
As Paulius says, cutting off after the first paragraph with no visible way of knowing you don't have the full text is very dangerous when sharing content.
It caused my team to miss a bunch of Acceptance Criteria :o
Luigi Romano
April 3, 2025
Hi @David Michelson
I see multi-line is not supported in the plugin
is it possible to parse the newline ("\n") to improve readability?
Jira ticket:
Jira-Confluence plugin
Thank you,
Luigi
