Sign up Log in
Prevent Confluence Down by limiting attachment copying with js code (1min)
If attachment > 300 can't copy.
If your company uses Confluence Server/Data Center, make sure to apply and share this tip with the admin. It will fundamentally resolve the issue of Confluence going down (without any apparent reason). Simply copy and paste the following JavaScript code at
<confluence_url>/admin/editcustomhtml.action > At end of the BODY. It only takes 30 seconds.
The core of this code is to prevent the copying of a page if it has more than 300 attachments. When copying a page, the background process of copying all attachments from the original page can significantly impact Confluence's performance. There may even be pages with thousands of attachments. Additionally, no logs are generated.
Typically, a single page shouldn't need more than 300 attachments. You can adjust this 300-attachment threshold to fit your company's situation. By preventing the copying of heavy pages (which is very easy to apply), you can easily resolve the issue of Confluence going down.
<script>
AJS.toInit(function() {
    var pageId = AJS.Meta.get("page-id");
    function fetchAttachments(start, totalFetched) {
        AJS.$.ajax({
            url: "/rest/api/content/" + pageId + "/child/attachment?limit=200&start=" + start,
            type: "GET",
            success: function(data) {
                var attachmentCount = data.results.length;
                totalFetched += attachmentCount;
                if (attachmentCount === 200 && data._links.next) {
                    fetchAttachments(start + 200, totalFetched);
                } else {
                    displayAttachmentCount(totalFetched);
            error: function(error) {
                console.log("Failed to fetch attachment information.", error);
    function displayAttachmentCount(count) {
        if (count > 30) {
            var color = 'black'; // Default color
            if (count > 100) {
                color = 'red';
            } else if (count > 50) {
                color = 'blue';
            AJS.$('#action-menu-link').after('<span id="attachment-count" style="color:' + color + '">(' + count + ')</span>');
            document.getElementById('action-copy-page-link').innerHTML = '<span style="color:' + color + '"> Copy (' + count + ')</span>';
    fetchAttachments(0, 0);
</script>
<script>
document.addEventListener("DOMContentLoaded", function() {
        AJS.$.ajax({
            type: "GET",
                } else {
        // Add event listener for 'Copy' link click.
        var copyPageLink = document.getElementById('action-copy-page-link');
        if (copyPageLink) {
            copyPageLink.addEventListener('click', function() {
                setTimeout(function() {
                    var copyAttachmentsContainer = document.getElementById('copy-attachments-container');
                    if (copyAttachmentsContainer && count > 30) {
                        if (count > 100) {
                            color = 'red';
                            color = 'blue';
                        var attachmentCountSpan = document.createElement('span');
                        attachmentCountSpan.textContent = ' (' + count + ')';
                        attachmentCountSpan.style.color = color;
                        copyAttachmentsContainer.appendChild(attachmentCountSpan);
                }, 500); // 500ms delay
    // Start fetching the number of attachments.
</script>
<script>
        AJS.$.ajax({
            type: "GET",
                } else {
                    processAttachmentCount(totalFetched);
    function processAttachmentCount(count) {
        if (count >= 300) {
            // Disable 'Copy' button if there are more than 300 attachments.
            if (copyPageLink) {
                copyPageLink.style.pointerEvents = 'none';
                copyPageLink.style.opacity = '0.5';
/** Add text to the lock icon */
function add_restrict_text() {
    /** Restriction message */
    // Get the element
    var element = document.getElementById("content-metadata-page-restrictions");
    // Get the value of the original-title attribute
    var originalTitle = element.getAttribute("title");
    // Print the value
    console.log(originalTitle);
    /** Check for class existence (red color) */
    // Get the element
    var locked = true;
    // Check if the class exists
    if (element.classList.contains("aui-iconfont-unlocked")) {
        console.log("aui-iconfont-unlocked class exists.");
        locked = false;
        if(element.classList.contains("restricted")) {
            locked = true;
     * originalTitle: Text displayed when hovering over the lock icon
     * locked: true==unlocked icon, false==lock icon
    var existingElement = document.getElementById("page-banner-end");
    // Create a new span element
    var newSpanElement = document.createElement("div");
    // Add attributes to the new span element (e.g., id and class)
    newSpanElement.setAttribute("id", "new-span-id");
    newSpanElement.setAttribute("class", "new-span-class");
    // Set top margin
    newSpanElement.style.marginTop = "10px";
    // Add text content to the new span element
    newSpanElement.textContent = "No Restrictions";
    if(originalTitle == "Restrictions apply" || originalTitle == "제한 적용") {
        if(locked) {
            newSpanElement.textContent = "View/Edit Restrictions";
            newSpanElement.style.color = "red";
        } else {
            newSpanElement.textContent = "Edit Restrictions";
            newSpanElement.style.color = "blue";
    // Insert the new span element after the existing element
    existingElement.insertAdjacentElement('afterend', newSpanElement);
// Get the target element to observe
var targetElement = document.getElementById("content-metadata-page-restrictions");
// Create a MutationObserver
var observer = new MutationObserver(function(mutations) {
  // Call the function to handle class changes
  handleClassChange();
// Observer configuration
var config = { attributes: true, attributeFilter: ["class"] };
observer.observe(targetElement, config);
// Define the function to handle class changes
function handleClassChange() {
  // Write the function or code you want to execute here.
  console.log("Class has changed!");
  // You can call additional functions or write more code here.
  // Get the element
  var elementToRemove = document.getElementById("new-span-id");
    // Check if the element exists and remove it
    if (elementToRemove) {
    elementToRemove.parentNode.removeChild(elementToRemove);
    } else {
    console.log("Element to remove not found.");
  add_restrict_text();
</script>
1 comment
Reese
Surely Scriptrunner @Reece Lander _ScriptRunner - The Adaptavist Group_ can add some safeguards for number of attachments on a page?
Or better yet - Atlassian can fix underlying issue? Agree 300 attachments might be excessive, but I am not sure I pages close to this many attachments.
Register Now
Upcoming Confluence Events
