A way to build an automation to remove the label from the original document but not the copy?
Saša Rosić-Milinković
Hey all,
I use a label to always ensure that the latest release notes for my products are pinned on the relevant pages of our scroll viewport site.
I generally create the release notes by copying the latest release notes, deleting the content within them and adding new one. I know I can make a template for this, but I do it specifically so I don't forget to add the label to it and remove the label from the old release notes - which I do on occasion forget to do and have to correct later on.
I've tried building an automation that basically says:
If page is copied
Then remove the label 'scroll-help-center-pinned-page'
However, that removes the label from the copied page, and not the original, so the exact opposite of what I want to happen.
Is there a way around this?
Aron Gombas _Midori_
September 30, 2024
It seems to me that the "page copied" trigger doesn't offer the original page in a smart value. So your approach will not work.
Workaround idea:
Using the "page copied" trigger, in the rule run this CQL:
label = 'scroll-help-center-pinned-page' and created < now("-10m")
It will basically return every page that is older than 10 minutes and has that label. If there are zero hits, then all page is fine. If there is one hit, then it is the original page -> you can remove the label from {{page}}.
Even if it doesn't work as is, it may give you an idea.
September 30, 2024 edited
Hmm, this would work if I only had this in one space across the entire Confluence documentation base. However, we have release notes written/published in multiple spaces. You might've given me an idea though; I'll try to create one that would only remove the label from any documents in the same space where the new document was copied from (if you have an idea on what this could look like, feel free to suggest).
Thanks for the great suggestion!
Like • Aron Gombas _Midori_ likes this
September 30, 2024
Note that there is a concept of "space-specific" automation rule!
There are "global" rules, but there are the ones that are active only within a space. So I think you can just use those.
@Aron Gombas _Midori_ I just realized this yesterday afternoon, and I am working with space-specific automation for that reason. However, this CQL didn't have the desired effect. This is how I built the rule:
Any suggestions on how I can tinker with this to try and make it work?
October 2, 2024
No, this is not what I mean.
What the rule above does: it is triggered by a page copy, then the test the new page (not the original one!) if it was created more than 10 minutes ago and has the label, then removes the label. It is obviously not what you want, it doesn't do anything.
What the rule should do: it is triggered by a page copy, but completely ignores the smart values populated by the trigger. Instead it runs the CQL, then removes the label from all pages resulted from the CQL. For this, you should use the Related entities kind of branching, I think.
Like • John Funk likes this
John Funk
September 30, 2024
Hi SaÅ¡a,
Can you share the rule that you have so far?
Hi @John Funk
Here's a screenshot:
atlassian, atlassian community, loom ai, atlassian loom ai, loom, atlassian ai, record recaps of meetings, meeting recaps, loom recaps, share meeting recaps,
Loom’s guide to great meetings 📹
Register today!
