AI Intelligence Writting Tone
adenau
January 17, 2024
Is there a way to train the AI Intelligence in Confluence to mimic the tone that is used in the other pages in the space? The idea would be to have a model that mimic my writing styles and puts emphasize on words I have used before.
Alex
Guensayn March 6, 2024
While it's not a perfect science, I've found that consistency is key. Stick to your usual writing style, and Confluence's AI tends to catch on. Also, don't shy away from a bit of manual tweaking post-generation.
Another handy trick is using Confluence's version history. Analyzing your past pages can help the AI understand your writing nuances better.
You can check out supermachines.io for more info about AI products. It can help you choose the best tool for your needs. Good luck!
Oliver Siebenmarck _Polymetis Apps_
January 17, 2024
Hi @adenau ,
There's nothing like that in the core product, but you might want to take a look at Connie AI. While that app is targeted towards search, it does take your data into account and maybe you can convince the AI (or the team behind it) to write in your style/voice.
Hope that helps,
 Oliver
Nikola Perisic
Hello @adenau ,
Currently AI is not offering this feature of tone mimic. For now only the ones that are within the AI (casual, professional,etc...).
Please mark the answer as accepted if you liked the answer, I would appreciate it a lot.
