Add a caption feature does not work in Edge browser
정대규
December 12, 2024
The add a caption feature works fine in Chrome browser, but in Edge browser, I can't enter content even when I double-click. What settings should I change?
4 votes
Ruth Schneider
January 8, 2025 edited
Here is a workaround that works for me until Atlassian fixes the bug:
In edit mode click on the picture for which you want to add a caption
Press the tab key
Enter the caption
Press Enter
I hope this helps :)
You might want to vote for the bug in the meantime:
[CONFCLOUD-80384] Image description is not working as expected in Edge browser. - Create and track feature requests for Atlassian products.
Ellen Niles
January 8, 2025
That workaround worked for me and once it exists as a caption, I can just click into it, don't have to use the tab key again :)
Voted on the bug.
Appreciate it!
Like • Ruth Schneider likes this
3 votes
Ellen Niles
December 13, 2024
Same issue here, updated browser, still experiencing.
Version 131.0.2903.99
Not able to click the caption, goes to next line
3 votes
Pete Bath
December 13, 2024
Having the same issue in edge. Click the add caption and it just goes to the next line. Must be a bug.
Manuel Negru December 17, 2024 edited
+1 We are experiencing the same issue. Chrome is working fine.
Tim Jacobs
January 7, 2025
We are experiencing the same issue. I have just reopened the case with Atlassian.
Ruth Schneider
Same issue here, Edge Version 131.0.2903.112
See inside
