Adding an info panel inside a list
rebecca_m_kornblum
Does anyone have a workaround that allows you to add a panel inside a numbered or bulleted list?
2 accepted
Kristian Klima
November 27, 2024
Hi @rebecca_m_kornblum
To get around the limitation, we're using emoticons from the Emoji menu.
The general consensus is that a) it does the job, b) it actually works better because it does not break the text so much as a dedicated big frame.
Barbara Szczesniak
November 27, 2024
I use this same method. If the note/tip/etc doesn't need to be a separate paragraph, I just stick the emoji before the text within the bulleted or numbered list item.
Like # people like this
Kristian Klima
November 27, 2024
I use soft-return to force a 'non-paragraph' in a list :D
Not ideal if I need to combine this with images and various levels of list indents though.
rebecca_m_kornblum
Brilliant and simple ... the best combination. Wondering why I didn't think of this. :) Thank you!
Like Kristian Klima likes this
Kristian Klima
November 27, 2024
You're welcome!
Like rebecca_m_kornblum likes this
Vronik
November 26, 2024
rebecca_m_kornblum
Thank you ... I will look through that today.
Like Vronik likes this
