Adding numerical values to a page
Lasse Kamp October 8, 2020
I use Confluence as a proces library for the companies processes. Each proces is a page. Example:
Finance
  Proces 1
  Proces 2
Sales
  Proces 3
  Proces 4
etc...
The processes are grouped within each area (Under Finance there would be a group called Daily and one called Month End)
Each proces have labels to indicate with systems and users that handles the proces. I can then make a report to see which processes are using a certain system. This works well :-)
But I would like to add some values to a proces (page), that could be Time Spend. Then I would like to be able to make a report on this and maybe addingup the values.
Is this possible?
Best regards
Lasse
Katerina Rudkovskaya [Stiltsoft]
Hello @Lasse Kamp ,
You can try the Table Filter and Charts for Confluence app.
Its macros help to filter, transform table data, make calculations, create pivots and then visualize it. It may help you with the case.
Best regards,
Katerina
