Sign up Log in
Any solution about design customized page and do some compute on confluence page
Owen
Is there any way to  achieve below function on one confluence page:
1.  Drop down list as answer  to  some query;
2.  Do some compute with script Runner on click button based on step 1's choice;
3. If no third part plugins (only Script Runner) , can we make it? If need plugin, which plugin can be used for such need?
James Noah
July 27, 2024
Yes, you can achieve the desired functionality on a Confluence page:
  1. Drop-down List: You can use Confluence's built-in macros or custom HTML to create a drop-down list.
  2. Compute with Script Runner: ScriptRunner can execute scripts based on the drop-down selection when a button is clicked.
  3. No Third-Party Plugins: If only using ScriptRunner, you might be limited in UI customization. For more advanced features, consider the Forms for Confluence or ConfiForms plugins.
I use this method for my website through HTML and JavaScript to create drop-down lists and handle computations based on user selections.
Owen
I found 1  possible way to achieve my goal without plugin.  I am trying now.
-- confluence user marco with javascript.
