I am trying to export individual spaces using the command
-a exportSpace --space "<ABC>" --file "Downloads/{name}.zip" --exportType XML
But when I try to import the exported space in another Confluence Cloud instance, it throws an error.
Is there any modification required in the command?
Thanks for responding, I was able to connect with Support. The problem was with duplicate keys.
Hello @Naman Batra
Please could you give us a screenshot of the error?
Also, from my experience in exporting from DC/Cloud and re-importing in Cloud, I have noticed that restoring through:
Settings -> Import Spaces
Is safer and much more consistent.
Hope that helps!
@Alessandro Cuccaro [ServiceRocket]- Thanks for your response. Is there anyway to import multiple spaces?- CLI/API/Script option?
We have over 200 spaces and don't want to import each manually.
Register today!Online forums and learning are now in one easy-to-use experience.
