Attachment macro - multiple labels does not work
Heather W June 7, 2021
I have a page with multiple attachment macros set up to organize the files. One of the macros has 4 labels in the macro's settings. When I updated a document with one of those 4 labels, it isn't getting associated with that macro. Even with 2 labels, that function didn't work; I could only get it to work with one label.
Is there a trick to setting them up (comma doesn't work) or is this a bug?
TIA,
Heather
Fabienne Gerhard
Hi @Heather W
as in documentation written here, multiple labels for attachments written should be separated using commas. Doesn't matter setting space after comma (checked it out). What does not work is using Upper- and lower cases in the settings of the macro.
What is happening when you click Preview when using 2 labels, 3 labels and than 4 labels?
Maybe there are also other settings that don't match to the mentioned 4 labels?
Hope this helps - feel free to ask for more help.
Cheers Fabienne
Heather W June 9, 2021 edited
Hi Fabienne,
Sorry, the issue is the macro label setting not the label on the document. If I put more than one label in the macro settings, then any document with one of those labels doesn't get picked up by that macro.
As I mentioned, I tried with commas - doesn't work. Only works with one label set up in the macro.
Thanks.
