×Hi,
So I have a Confluence page which contains a Attachment Macro. Now this attachment Macro has a label setup.
When I upload a image/attachment it does not show the attachment in the file list overview on the confluence page for the simple reason that that image does not inherit the label from the attachments Macro.
This used to work previously but now all of a sudden it does not.
Any idea what change here? Am I missing a step?
I don't want to remove the label from the macro as I want to have an overview of attachments which contain that specific label.
Thanks in advance.
Hi @Howard Nedd ,
I know that it worked if you used the upload button - drag & drop never worked - at least based on my knowledge.
Our app Attachment Boxes closes this gap.
Best regards
Andreas
Thank you for the useful reply. This is the case indeed and it resolves my problem here.
Howard
Hi @Howard Nedd
You do not add label to attachments macro, but rather to an individual attachment.
The Attachment Labels parameter in the attachments macro is used to filter the attachments to display. Confluence will show only attachments that have all the labels you specified.
So once you upload an attachment you should label them first. To add labels to an attachment:
Let me know if this works for you after adding label to your attachments.
Hi Kishan,
Thank you. I already understood this way of doing it but this was not the user case.
Howard
