Auto-highlight active promotions depending on their timeframe
Ionut
Hi guys,
So I have a shop and I've created a knowledge base for my customers. I also have promotions commencing every ~week and I want to highlight the active ones in my space.
For example: I have a promotion which will end on 10th of June and I want it to be shown as active in my space. Once the promotion end-date is reached I'd want confluence to automatically move it to a dedicated page with "Offline promotions".
Do you think is feasable? Or maybe I need to find another approach to this?
Thanks in advance,
Ionut
SMS
June 12, 2020
Hello Ionut,
I hope you are doing well!
To answer your question, there are a few automation add-ons on Atlassian Marketplace. I haven't personally used these, but apps like ScriptRunner could help you automate some internal things within Confluence.
Otherwise, you might want to think about developing something internally that can work with Confluence in that way. Have a look at the Confluence Cloud Development documentation for more information on that.
If you do decide to go that route, we have a page of Developer Resources in case you run into trouble.
I hope this helps get you in the right direction, but let us know if you have any further questions.
Shannon
Ionut
Hi @Shannon S ,
Thanks a lot, this was very helpfull.
Ionut
Like SMS likes this
SMS
June 15, 2020
Hi Ionut,
Happy to at least point you in the right direction! Take care, and have a pleasant week.
Take care,
Shannon
Like Ionut likes this
