Automation; display results of web request in table
Brian King
September 27, 2025
I've setup a new Confluence Automation Rule which calls an API, and gets back a list of items.
I've got an 'Edit Page' action which is editing an existing page to append the results.   The results are in a 'Smart values code snippet' as below:
{{#webResponse.body.issues}}
   {{fields.duedate}} {{key}} {{fields.summary}} {{fields.status.name}}
This is working fine, with the results being appended to the page.  However I'd like the results to be displayed as a table.  I've not been able to work out how to do this.
4 votes
September 28, 2025
Hi @Brian King -- Welcome to the Atlassian Community!
Please review this article from Atlassian describing how to use the Confluence page actions with a list of items to add a table:
https://community.atlassian.com/forums/Automation-articles/We-ve-enabled-rich-text-editing-in-the-Publish-new-page-in/ba-p/3041023
The steps to create a table are specific and a bit hidden in the examples:
  • In the Edit Page or Create page action for the Page Content...
  • Enter three single left-quote marks to enter the Smart Values Code Snippet feature:
  • Following the examples in that article, add your table layout and list iteration content.  Please note well: this markup syntax is different than the one used for rich text fields.
For the list iterator you show, that could be this:
| Due Date | Key | Summary | Status |
| {{fields.duedate.jiraDate}} | {{key}} | {{fields.summary}} | {{fields.status.name}} |
Also, I recommend writing that expression to the audit log to confirm it contains what you expect.  This will help with debugging any page updates.
Brian King
September 28, 2025
Thank you Bill, that formatting did the trick and its working as hoped.
Like Bill Sheboy likes this
David Nickell
September 28, 2025
This looks like Work Item data, which, you could use a Filter Results Widget on the confluence page to display.   Instead of creating  the displayed results, use your automation to flag the results in JIRA (perhaps with a label or dedicated checkbox).  then all the basic tools (FIlter, Confluence widget) will do all the heavy lifting for you.  In addition, your flag (or filter) can be used to drive other reporting or meeting discussions.
One other thing -- be sure you know how long you want the results included on your page.
  • You may want to clear flags before your automation runs so as to keep the return list accurate
  • Or, maybe the list is also governed by some other attribute.  For example your page is sprint specific so your filter should include sprint in the JQL.
I'm guessing by the time you've read this sentence you've already coded a workable solution :-).  Hope this helps
