Hello
is it possible to use Confluence Automation inside the Confluence Database?
My goal would be to :
* display some issues in a database (followup meeting with some managers). Some columns will shos the issue link, some spare fields
* add a text field in the columns that is "New comment"
* when a new Comment is entered, I'd like to use automation to create a new comment on the jira issue itself
this would finaly provide some "embed Jira into Confluence" reality, in the form aof a easy to use table
thank you
Vincent
Your use case absolutely makes sense, but as far as I know there is currently no automation trigger available for Confluence Databases. Especially not with the granularity of a single cell-level update.
I'll be really excited to see automation capabilities with Databases as the feature gets more established!
Agreed, automation, especially between Jira and Confluence Databases makes much sense!
Help us plant more trees
