I'm looking for best practice advice to ensure the right confluence articles are presented to end-users from the Help Center/SD form.
Following some testing when raising a SD ticket an article with vpn in the title & also added to labels is not presented to the user, despite having vpn in the summary field, unless the word open is also added. Examples below:
VPN only - Article missing
open & VPN - Correct article presented
Article title
Labels stored with article
As a result, the right articles are not being presented & ticket deflection is not as effective as it could be, what are we missing?
If you search for the word "Only", does it show the "VPN only" article? - no
Is this issue happening only with this article? - at the moment yes.
If you search through the Search option on the top of the page, does it show the article? - not sure what you mean.
Thank you for the information, Joshua.
The search is related to the general search in the customer portal.
Please, check if it shows something different from the articles that appear when creating a ticket.
It does not appear, We have the correct tags however when users are making tickets there are not clicking on the KB's because there are not showing please advise?
Should i make a tickt so you can view our jira config?
Josh
Thanks, Joshua.
If the page is part of a space linked to the Service Desk and the page is open to the customers, it should appear.
The labels on the page work for Confluence, but in the Customer Portal, it considers only the title of the page.
Have you checked the permissions of the page? When a space is added to a Project, all pages must be opened for it to show in the Portal.
Related to the ticket, if you are the site administrator of the site, you can create one on support.atlassian.com. Here is community we can try to help by testing on our test sites and with the information and steps that you shared, we can try to replicate. With the support ticket, you can allow us to access your site and we can check directly what is happening.
Apologies for the delay, been a busy week, I'll open a support ticket directly so we can take a look at this
Josh
Hello Karyn,
I'm not sure how many articles are available on the space linked to your Service Desk project, but I tested here and using the same titles as you and it shows the articles correctly:
By default, it only shows three results when we add a keyword in the summary, is it showing only those two?
With these details, we will be able to better understand what is happening on your site.
Angélica
Hello Angelica,
We have tested using this, however on our VPN KB, it has vpn & VPN on its tag, is the tagging system case sensitive? - can it be that we can only do one-word tags, as the system does not allow us to do any more than one word as a tag
Josh
Hi Joshua,
Welcome to Community!
I tested here and searching using "vpn" or "VPN" it shows the same results.
I created pages using the same title as your articles and it shows in the customer portal. The search in the portal is limited to only three results:
