Better Code Block doesn't work
박수빈_WM_
October 1, 2025
Hello.
The Better Code Block used by Confluence is not working
Tell me what to do plz
(I am a user who does not have organization administrator privileges)
If possible, you can answer in Korean
Tomislav Tobijas
Hi @박수빈_WM_ ,
I would answer in Korean if I could, but my suggestion would be to use Google Translate...
Anyway, to the topic—as stated in the Action Required section, the Confluence administrator (maybe just Org admin now) would need to update the app.
So, if you could just reach out internally to your app/Org admins to make an update, I believe that would resolve the issue you're seeing. 👈
Tobi
