I've tried with and without defining an excerpt section in a blog post, but the excerpt setting in the macro only shows the title, author, and date of post. Not sure how to fix this.
Hello @Patrick Mazzotta !
This behavior is quite new and has been filed this report here:
Currently, there is no ideal workaround that allows us to display the excerpt content. The only way would be to show the entire post. The best course of action would be to vote and watch the report. Voting helps to increase the visibility and watching it will keep you up to date with everything posted there.
Let us hear from you!
Excerpts still do not work properly. What is the problem?
Still doesn't work.
The problem is with Atlassian. I could understand missing feature. But they don't care about exposed already features which don't work. Not the first nor the last.
Read more 📚Online forums and learning are now in one easy-to-use experience.
