I would like to create an automation, that changes the page permissions of all child pages of a certain page branch.
I already tried this, but its not working, as the child pages cannot be found or no actions are performed. When looking up the audit log, i cannot find any id of any child page.
Automations also say "This Branch contains all 249 elements" but i know, that there are more than 1.500 pages and elemts?
What am I missing? Is there a possibility to bulk change permissions of a page and all the pages in that branch? A possibility that is not script runner or some other thrid party app, as we have very strict rules concerning new apps.
Thank you!
Hey @Langer Lukas
you're currently looking for pages which have a parent of xxx. Do all 1500 pages have this parent or are there pages in your tree which life further down the tree?
If so, you might want to use "ancestor" instead of "parent"?
Ancestor:
Search for all pages that are descendants of a given ancestor page. This includes direct child pages and their descendents. It is more general than the parent field.
Parent:
Search for child content of a particular parent page.
Hope this helps.
Steffen
Hey @Steffen Burzlaff _K15t_ !
Thank you - this is exactly the thing I was looking for! I will give it a try!
Hi there,
I tried an automation that looked like this and it worked for changing the restrictions to the parent page.
Hope this helps you some
Hello!
Basically both answers are acceptable!
I used the wrong branch, so the branch of @Maja Vallin is correct and for this reason this answer is to accept.
But, I was looking for the CQL field reference @Steffen Burzlaff _K15t_ told me.
So the correct answer is a combination of both your answers.
@Maja Vallin the Atlassian support already helped me with the problem, but thanks for your answer, so future help-seekers can use this!
