Can I create a TableView and a CardView together
Rayman Bacchus
In Confiforms I have created a CardView that a few managers on the team will use to review project intake informations (requirements, due dates, etc....).  I also have a TAbleview from a separate form that tracks Action Items (item, required by, due date, etc...).  The two are linked in a Confluence Page by the filter IntakeRef=[entry.id] so only the action items related to the actual intake number will be shown on the Confluence Page.  Meanwhile IntakeRef (from the task form) is a SMARTVIEW of all the Intake Reference Numbers from the main intake form.
Is there a way to combine the CardView (which shows data from the main Intake Form) and a TableView (which will only show items from the Task Form)?
Alex Medved _ConfiForms_
Not sure why you want to complicate the things like that, but look at the queryAndRender function https://wiki.vertuna.com/display/CONFIFORMS/Virtual+functions
Rayman Bacchus
What I have done is this:
so basically created a field in the CardView with the queryAndRender function:
id.queryAndRender(FY24FrdIntakeTasks:2634557043;IntakeNumber:[entry.IntakeRef];IntakeRef|Tasks|Assigned|Status|DueDate;table)
This shows ALL rows in the form FY24FrdIntakeTasks, so about 50% there.
I have also tried this:
id.queryAndRender(FY24FrdIntakeTasks:2634557043;IntakeRef:[entry.IntakeNumber];IntakeRef|Tasks|Assigned|Status|DueDate;table)
which I think should be the correct query, but that doesn't seem to show anything
What is IntakeNumber ? And what is IntakeRef?
Rayman Bacchus
Intake Number is from the main form and is a alphanumeric field something like (FY2024-1182)
Intake Ref is the same thing but the "sub Form"
So basically I want to queryandRender the subForm and have it show the tasks in the subform on the main view.
September 27, 2024 edited
Both are text fields?
Rayman Bacchus
Hi Alex:
I got this to work.
id.queryAndRender(FY24FrdIntakeTasks:2634557043;IntakeRef:[entry.id];IntakeRef|Tasks|Assigned|Status|DueDate;table)
The card now shows the tasks as required.
Thanks, as always for your help.  It is a pleasure
So, one of the fields is actually a smart field... OK, it makes sense now
Like • Rayman Bacchus likes this
Rayman Bacchus
Hi Alex:
Graphically may explain things better.  This is what I want:
Where MergedIntake.IntakeNumber = FY24FrdIntakeTasks.IntakeRef.
In the meantime, I'll take a look at the function you mentioned.
No, this does not work - https://wiki.vertuna.com/display/CONFIFORMS/ConfiForms+app+detailed+view+over+the+plugin+macros
TableView/CardView are not able to render a nested macro
