Can we create JIRA Xray Test Case with Test Step using Rest API
Dnyaneshwar Shejul
August 25, 2025
Hello Team,
I'm able to create a Jira Xray Test and add a summary, description, and other fields using the '/rest/api/3/issue' API but I'm having trouble adding test steps using the REST API.
I've tried the following endpoints:
  • /rest/api/3/issue
  • /rest/raven/2.0/api/test
  • /rest/raven/1.0/api/test
Could someone please provide guidance on the correct API endpoint and method for adding test steps to an Xray Test?
Thanks in advance!
Tomislav Tobijas
Hey @Dnyaneshwar Shejul ,
Here's official documentation from Xray about their APIs: REST API, however, I don't think they mention exactly how test steps are added. You'll probably have to dive into GraphQL a bit more to find a solution.
Although I'd probably recommend reaching out to Xray official support team via their channels, as they can probably assist you better based on your requirement.
*btw, I've moved this question to Jira forum group
Tobi
ENTERPRISE
