Children Display Macro and Template
Margherita December 17, 2014
I have some issues with the Children Display macro.
I have this tree structure: TemplateA --> TemplateB --> TemplateC
into the "TemplateA" you find a button to create a document from the "TemplateB" and into the "TemplateB" you find a button to create a document form the "TemplateC"
If I use the {children display} in the TemplateA, it works fine and it creates the structure TemplateB --> TemplateC
Is it possibile use the {children display} also in TemplateB and TemplateC to show the entire hierarchy (TemplateA --> TemplateB --> TemplateC) so user can move easily form one document to another?
I would like to show both children and parent pages...
Thanks for your time and help,
Margherita
Deividi Luvison
December 22, 2014
Hey Margherita,
I think you can achieve that if you use the page include macro:
https://confluence.atlassian.com/display/DOC/Include+Page+Macro
If you include the page A into there you would be able to see the table of content of page A, the only problem is that it would display any content of that page, which I don't know if helps you or not sad.
Thanks and Regards,
David| The Engineer that like Windows for realsies.
